jongor Posted June 10, 2009 Posted June 10, 2009 Oh.....buy why? I need a 1/2" radius. I'm actually trying to build a 3-D model to be used in a CNC machine to cut out a real guitar body. Quote
shift1313 Posted June 10, 2009 Posted June 10, 2009 The reason you are having issues is because of a "jog" or "step" somewhere in the geometry. Probably around where the neck of the guitar should start. When you run into geometry that has sharp corners or small bends(like at the neck) Acad can not solve the fillet. If you simplify your geometry you should be able to get it to work out just fine. Quote
