stenews Posted October 29, 2021 Posted October 29, 2021 (edited) Hi to everyone, I'm trying to convert a .dwg file to an Autocad Inventor .step file I haven't AutoCad Inventor installed on my workstation so I'd like if some of you can make the conversion for me. I'm not a fun of Inventor and I use most of the time Autocad that's why I hope if you can make my drawing suitable for CNC machining step center. I appreciate any help, Stefano flangia_flex.dwg Edited October 29, 2021 by stenews Quote
BIGAL Posted October 30, 2021 Posted October 30, 2021 For cnc dont you need Gcode ? Lots of programs out there for Autocad. Quote
stenews Posted October 30, 2021 Author Posted October 30, 2021 (edited) 20 hours ago, BIGAL said: For cnc dont you need Gcode ? Lots of programs out there for Autocad. Thanks BIGAL you're right but I'm not going to make any Gcode a friend of mine will do it for me. I only need to give him a .stp file format of my previously .dwg drawing That's what I was looking for... I'll try to manage with AutoCad Mechanical I appreciate your help Edited October 30, 2021 by stenews Quote
SLW210 Posted November 1, 2021 Posted November 1, 2021 It didn't convert very well here. Had some parts off in the distance. What is your friend using to convert? Most can use .dxf direct to the CNC software, most converters to G-Code as well. Perhaps, if possible, you could use a trial version of a newer AutoCAD to play around with it some. What version of Mechanical are you using? Quote
stenews Posted November 7, 2021 Author Posted November 7, 2021 (edited) Hi SLW210, I was trying to convert it with Inventor 2017 He just asking to me a step file...I really don't know what kind of G-Code he has got In your opinion is better to convert it with AutoCad Mechanical or with Inventor Thanks for your reply and sorry for my late aswer flangia_flex.stp Edited November 7, 2021 by stenews Quote
SLW210 Posted November 8, 2021 Posted November 8, 2021 Your STEP looks the same as the one I did. Objects off into space some. I did IGES and it seems pretty good. As to what's better, check with the CNC person. flangia_flex.iges Quote
stenews Posted November 9, 2021 Author Posted November 9, 2021 thanks a lot SLW210 I appreciate your help. Quote
