CarmeloLabadie Posted November 23, 2021 Share Posted November 23, 2021 I am learning technical drawing alongside tutorials from CADlearning for Autocad. What are some simple projects I could practice at this early stage? both in CAD and manually - What online resources are available for this? Note - I am not looking for anything specific in regards to the type of drawing i.e. a mechanical, electrical or architectural drawing, rather a workbook of making simple 2D & 3D shapes & objects and different ways of presenting them. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 23, 2021 Share Posted November 23, 2021 Look around your house/apartment. What do you see? OBJECTS! Anything you can pick up and actually measure can be used as the inspiration for creating a drawing in AutoCAD. Start small then work your way up to larger objects. Another option would be to go to your local library (remember those?) and check out a book about drafting. It should have plenty of examples of items that you can draw. Use your imagination! 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 24, 2021 Share Posted November 24, 2021 (edited) Look at the section here about Penn Foster lots of example dwgs you could try to duplicate. Like Remark draw your room. Edited November 24, 2021 by BIGAL Quote Link to comment Share on other sites More sharing options...
jagwinn Posted January 7, 2022 Share Posted January 7, 2022 Book attached: machinedrafting01willgoog.pdf Quote Link to comment Share on other sites More sharing options...
jagwinn Posted January 7, 2022 Share Posted January 7, 2022 CAD exercises: 20-days-of-2d-CAD-exercises-Part-I.pdf Quote Link to comment Share on other sites More sharing options...
jagwinn Posted January 7, 2022 Share Posted January 7, 2022 More: 323443663_practicedwgs2D.pdf Quote Link to comment Share on other sites More sharing options...
Soumya Suman Posted February 1, 2022 Share Posted February 1, 2022 You can take help from online as well as offline sources. If you are comfortable with online resources then you can go for some online sites like myCADsite, Cadalyst, CADTutor, Tutorial 45 and there are many more, but these are the best one for you because it has many practice paper as well as good tricks and tips. And if you are comfortable with offline resources like books then here are some best books for you "AutoCAD 2021 For Beginners. By Cadfolks", "Mastering AutoCAD 2019 and AutoCAD LT 2019. By George Omura", "Discovering AutoCAD 2020. By mark dix", "AutoCAD 2020 A Project-Based Tutorial. By Tutorial books". These are some best books for you, these books will help you out with creating as well as modifying image. You can also get help from YouTube. I hope this is helpful. Quote Link to comment Share on other sites More sharing options...
