vla-Offset directions
CarmeloLabadie
I'm a little confused... I've read in all the vla-Offset posts about the difficulty in determining the direction of the offset. Have things changed for 2007? I get the following consistent results:
LINE: + to left & - to right
ARC: + increase radius & - decrease radius
LWPOLYLINE: + to right & - to left
Obviously this makes things so much easier.
Link to post
Emmanuel Delay
Lines, polylines have a direction.
You can draw a line from left to right, or from right to left.
Just like polylines have an order of which point came first ...
Depending on that the offset can do the opposite thing, depending on whether the distance is positive or negative.
Test my code (type a number for getdist instead of setting two points) on the dwg I uploaded.
;; Custom OFFset
(defun c:coff ( / mspace myline dist offLine)
    (vl-load-com)
    (setq mspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
    (setq myline (vlax-ename->vla-object (car (entsel "\nSelect object to offset: " ))))
    (setq dist (getdist "\nOffset Distance : "))
    (setq offLine (vla-Offset myline dist))
offset.dwg
Edited by Emmanuel Delay
  • Funny 1
Link to post
BIGAL
Like mhupp answered some where else.
My $0.05 I use pick near end of line pline etc this determines the direction uses a compare end points to pick point.
Link to post
