Displaying z value of given point... next to it on screen in text
Hi all i have recently had to fix one total station surevy to a gps survey i have done on the same area... when i can to fix the ts survey to the gps... the levels in the text value didnt change to the new given value.... is it possible to do this eg a lisp or a quick way as i have over 2000 plus point to assign a level to?
Link to post
You need to use a lisp that does arithmetic on the text in the drawing. If your text is in the correct format, it should take but a few seconds.
Firstly, I would suggest you start with Lee Mac's web site and look at TextCalculator programme.
  • Thanks 1
Link to post
