I would need to please implement the following lisp.
what I want is that when I select the color of the selection is activated and then that I can select multiple objects / blocks with the window.
thank you
(defun c:enb ( / sel )
    (while
        (progn (setvar 'errno 0) (setq sel (nentselp "\nSelect nested block: "))
            (cond
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (null sel) nil)
                (   (null (cadr (setq sel (last sel))))
                    (princ "\nObject is not a nested block.")
                (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 (entget (car sel)))))))))
                    (princ "\nThe selected block is on a locked layer.")
                (   (vl-some 'enb:isxref (cdr sel))
                    (princ "\nThis program is not compatible with blocks nested within xrefs - sorry.")
                (   (vl-some 'enb:isdynamic (cdr sel))
                    (princ "\nThis program is not compatible with blocks nested within dynamic blocks - sorry.")
    (if sel
            (foreach lst (enb:getreferences (cdr (assoc 2 (entget (cadr sel)))))
                (apply
                   '(lambda ( mat vec / obj )
                        (foreach ent (cdr (reverse lst))
                            (apply
                                (function
                                    (lambda ( m v )
                                        (setq vec (mapcar '+ vec (mxv mat v))
                                              mat (mxm mat m)
                                (refgeom ent)
                        (if
                            (vl-catch-all-error-p
                                (vl-catch-all-apply 'vla-transformby
                                    (list (setq obj (enb:copy (car sel) (last lst)))
                                        (vlax-tmatrix
                                            (append
                                                (mapcar '(lambda ( m v ) (append m (list v))) mat vec)
                                               '((0.0 0.0 0.0 1.0))
                            (vla-delete obj)
                    (refgeom (last lst))
            (vla-delete (vlax-ename->vla-object (car sel)))
            (vla-regen  (LM:acdoc) acactiveviewport)
(defun enb:copy ( ent par )
    (eval
        (list 'defun 'enb:copy '( ent par )
            (list 'car
                (list 'vlax-invoke (LM:acdoc) ''copyobjects '(list (vlax-ename->vla-object ent))
                    (if (vlax-method-applicable-p (LM:acdoc) 'objectidtoobject32)
                        (list 'vla-objectidtoobject32 (LM:acdoc) '(vla-get-ownerid32 (vlax-ename->vla-object par)))
                        (list 'vla-objectidtoobject   (LM:acdoc) '(vla-get-ownerid   (vlax-ename->vla-object par)))
    (enb:copy ent par)
(defun enb:getreferences ( blk / ent enx lst )
    (if (setq ent (tblobjname "block" blk))
        (foreach dxf (entget (cdr (assoc 330 (entget ent))))
            (if
                (and
                    (= 331 (car dxf))
                    (setq ent (cdr dxf))
                    (setq enx (entget ent))
                    (setq enx (entget (cdr (assoc 330 (reverse enx)))))
                (if (wcmatch (strcase (setq blk (cdr (assoc 2 enx)))) "`**_SPACE")
                    (setq lst (cons (list ent) lst))
                    (setq lst (append (mapcar '(lambda ( l ) (cons ent l)) (enb:getreferences blk)) lst))
    lst
(defun enb:isxref ( ent )
    (= 4 (logand 4 (cdr (assoc 70 (tblsearch "block" (cdr (assoc 2 (entget ent))))))))
(defun enb:isdynamic ( ent / obj )
    (and (vlax-property-available-p (setq obj (vlax-ename->vla-object ent)) 'isdynamicblock)
         (= :vlax-true (vla-get-isdynamicblock obj))
;; RefGeom (gile)
;; Returns a list whose first item is a 3x3 transformation matrix and
;; second item the object insertion point in its parent (xref, block or space)
(defun refgeom ( ent / ang enx mat ocs )
          ang (cdr (assoc 050 enx))
          ocs (cdr (assoc 210 enx))
    (list
        (setq mat
            (mxm
                (mapcar '(lambda ( v ) (trans v 0 ocs t))
                        (1.0 0.0 0.0)
                        (0.0 1.0 0.0)
                        (0.0 0.0 1.0)
                (mxm
                    (list
                        (list (cos ang) (- (sin ang)) 0.0)
                        (list (sin ang) (cos ang)     0.0)
                       '(0.0 0.0 1.0)
                    (list
                        (list (cdr (assoc 41 enx)) 0.0 0.0)
                        (list 0.0 (cdr (assoc 42 enx)) 0.0)
                        (list 0.0 0.0 (cdr (assoc 43 enx)))
        (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
            (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
;; Matrix Transpose  -  Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
;; Matrix x Matrix  -  Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
    ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com)
(princ
    (strcat
        "\n:: ExtractNestedBlock.lsp | Version 1.2 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: Type \"ENB\" to Invoke ::"
;;                             End of File                              ;;
