Picking a MTEXT e replace a BLOCK ATTRIBUTE
jr.roberto.santos
Greetings everyone, I'm trying a way to select an MTEXT and Replace a block attribute.
The block name is HDV1_CONVERT (Attributes: TAG1F, DESC1, DESC2, DESC3…)
Best Regards
I assumed that you are after replacing all text strings in the selected attributed block HDV1_CONVER to selected string from Mtext so here is a draft to see if this meet your aim of the program.
(defun c:Test (/ int sel str ent get)
  ;; Tharwat - 23.Dec.2021	;;
  (and
    (setq sel (car (entsel "\nPick Mtext : ")))
    (or (= (cdr (assoc 0 (entget sel))) "MTEXT")
        (alert "invalid object selected. Try again")
    (setq str (cdr (assoc 1 (entget sel))))
    (princ
      (strcat "\nSelect Blocks to replace < HDV1_CONVERT > to replace < "
              str
              " > with all attributes with :"
    (setq int -1
          sel (ssget "_:L"
                     '((0 . "INSERT") (66 . 1) (2 . "HDV1_CONVERT"))
    (while (setq int (1+ int)
                 ent (ssname sel int)
      (while
        (and (setq ent (entnext ent))
             (not (eq (cdr (assoc 0 (setq get (entget ent)))) "SEQEND"))
         (and (= (cdr (assoc 0 get)) "ATTRIB")
              (entmod (subst (cons 1 str) (assoc 1 get) get))
  • Like 2
Tharwat
Thank you very much for your collaboration, for the code to be perfect, I just need to filter the attributes.
Example: DESC2 and DESC3
Please, see attachment with example DWG.
Best Regards
Sample_Drawing.dwg
Give this a shot and let me know.
  (and
    (setq sel (car (entsel "\nPick Text or Mtext : ")))
    (or (wcmatch (cdr (assoc 0 (entget sel))) "MTEXT,TEXT")
    (princ
              str
    (setq int -1
          sel (ssget "_:L"
      (while
         (and (wcmatch (cdr (assoc 2 get)) "DESC2,DESC3")
Edited by Tharwat
You can select Text or Mtext now
As a beginner, I must also thank you.
Tharwat thanks so much for the help, the response was instantaneous!
Best Regards
J. Roberto
