Gap for lines intersection
Samr1979
 Share
I'm looking for a LISP that lets me break lines that intersect at a desistance I tell it to. I haven't been able to find one yet? Any help will be useful.
Yes, that's doable.
Could you upload a dwg (/picture) of the desired result? So we know exactly what you want.
I don't have a lisp, but I use CAB's break lisp explained here: https://skillamplifier.com/break-selected-objects-autocad/
Then I use the lengthen command with negative distance, I have a shortcut for entering. Works well for a few lines, but because lengthen only accepts single object section, not a fence selection, it is tedious to pick lots of lines. (in Bricscad v15 at least)
(defun c:LD  () (command "LENGTHEN" "DELTA") (princ))
Edited by dan20047
What Dan posted is nice program but doesn't have an option for gaps so this is what I came up with.
Will remeber last gap distance used.
;; Breakes line with a gap.
(defun C:GapBreak (/ oldsnap lst val line cen cir dia a)
  (vl-load-com)
  (setq doc (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
  (setq lst (list 'cmdecho 'osmode)
        val (mapcar 'getvar lst)
  (mapcar 'setvar lst '(0 32))
  (setq line (car (entsel "\nSelect Line: ")))
  (while (/= (cdr (assoc 0 (entget line))) "LINE")  ;repeat until line is selected
  (setq cen (getpoint "\nBreaking Point: "))
  (setq dia (vlax-ldata-get "cir" "dia"))  ;checks for ldata and sets the variable
  (if (= dia nil) (setq dia "5"))          ;first time running it will default to value 5
  (if (= "" (setq a (getstring (strcat "\nGap Size [" dia "]: "))))
    (setq a dia)  ;if you hit enter it will set a to dia value else override it to what you input
  (vlax-ldata-put "cir" "dia" a)  ;Saves value to drawing
  (setq cir (vla-addcircle doc cen a))
  (command "_.Trim" cir "" (cons line (list cen)) "")
  (vla-delete cir)
  (mapcar 'setvar lst val)
Edited by mhupp
added vl-load-com
16 hours ago, Samr1979 said:
Emmanuel Delay, This is kind of what I'm talking about
That is what mine does but one point at a time. id use SLW210's since it handles multiple points at once.
3 minutes ago, dan20047 said:
Ronjonp - thanks! I totally missed that option in CAB's great tool.
Cheers! 🍻
 Share
