Replace item at sublist
rog1n
 Share
Hello, I am trying create a function that replace a item from a list with sublist (like a tree) with a sublist, so at momento I do this:
(defun test (lst o n)
  (if lst
    (cond
      ((= (type (car lst)) 'LIST)
        (list (test (car lst) o n))
      ((atom (car lst))
       (if (equal o (car lst))
	 (cond
	   ((atom n) (cons n (test (cdr lst) o n)))
	   ((= (type n) 'LIST) (cons n (test (cdr lst) o n)))
	 (cons (car lst) (test (cdr lst) o n))
if I execute with this list:
(setq number (list 1 (list 2 (list 3 (list 4 5)))))
(test number 5 (list 5 6))
--> result is (1 (2 (3 (4 (5 6))))) work like I need
but if I tried with this list:
(setq number2 (list 1 (list 2 (list 3 (list 4 5))) 7))
(test number2 5 (list 5 6))
--> result is (1 (2 (3 (4 (5 6))))) dont work, the correct result is: (1 (2 (3 (4 (5 6)))) 7)
or
(test number2 7 (list 7 8))
--> result is (1 (2 (3 (4 5)))) dont work, the correct result is: (1 (2 (3 (4 5))) (6 7))
If possible, anyone can help me to fix the code?
https://documentation.help/AutoLISP-Functions/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-689a.htm
;;---------------------=={ Subst Nth }==----------------------;;
;;  Substitutes an item at the nth position in a list.        ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  a - item to substitute                                    ;;
;;  n - position in list to make the substitution             ;;
;;  l - list in which to make the substitution                ;;
;;  Returns:  Resultant list following the substitution       ;;
b - item to be replaced
(defun LM:SubstNth ( a b l / i n)
  (vl-load-com)
  (setq i -1)
  (if (setq n (vl-position b l))
    (mapcar '(lambda ( x ) (if (= (setq i (1+ i)) n) a x)) l)
(LM:SubstNth 10 4 '(5 4 3 2 1 0))
(5 10 3 2 1 0)
Edited by mhupp
Still nothing work I belive its because I have list inside others list
check the example:
(setq lst  (list 1 (list 2 (list 3 (list 4 5)))))
(LM:SubstNth 5 6 lst) -> nil
1 hour ago, mhupp said:
Any reason your running 3 or 4 levels deep with lists?
I am trying make a scheme with parent and child
Do you have a better solution?
I don't know exactly how to explain it.. either I will look brilliant by saying what I think or everyone will say "no it's not that at all you fool". Anyway I think it is all to do with moving along the nested lists until there is no more lists but it can't then 'un-nest' back up the levels.. I think...
So what I thought is you might need to explicitly loop through each item in the list and analyse that as you loop through and repeat as you come to a new nested list, when that nested list is finished the loop moves onto the next item in its parent list.. or something like that
Anyway, you could try this:
(defun testlist (mylist mysearchterm myreplace / Newlist)
  (defun checklist ( alist mysearchterm myreplace / acount mylist)
    (defun LM:SubstNth ( a n l )
      (if l
        (if (zerop n)
          (cons a (cdr l))
          (cons (car l) (LM:SubstNth a (1- n) (cdr l)))
    (setq acount 0)
    (while (< acount (length alist))
    (if (= (TYPE (nth acount alist)) 'LIST)
      (setq mylist (LM:SubstNth (checklist (nth acount alist) mysearchterm myreplace ) acount alist))
      (progn ;;if not list
        (if ( = (nth acount alist) mysearchterm)
          (setq mylist (LM:SubstNth myreplace acount alist))
        ) ; end if
      ) ; end progn
    ) ; end if
    (setq acount (+ acount 1))
    ) ; end while
    mylist
  (princ "My Old List: ")
  (princ mylist)
  (princ ". Subs: ")
  (princ mysearchterm)
  (princ ". New Item: ")
  (princ myreplace)
  (setq Newlist (checklist mylist mysearchterm myreplace))
  (princ " : My New List: ")
  (princ Newlist)
  • Thanks 1
      (if l
        (if (zerop n)
          (cons a (cdr l))
    (setq acount 0)
        ) ; end if
      ) ; end progn
    ) ; end if
    ) ; end while
    mylist
  (princ mylist)
  (princ ". Subs: ")
  (princ myreplace)
  (princ Newlist)
I am trying to understand what you do, anyway its working like I need,
thank you all for the help!
Hi
Here is a simple function, works for any nesting level
(defun replace_sublist (lst old new)
  (mapcar
    (function
      (lambda (x)
        (cond
          ((equal x old) new)
          ((atom x) x)
          (T (replace_sublist x old new))
    lst
And some tests
_$ (setq number2 (list 1 (list 2 (list 3 (list 4 5))) 7))
(1 (2 (3 (4 5))) 7)
_$ (replace_sublist number2 5 (list 5 6))
_$ (replace_sublist number2 7 (list 7 8))
(1 (2 (3 (4 5))) (7 8))
_$ (replace_sublist number2 (list 4 5) 4)
(1 (2 (3 4)) 7)
_$
  • Thanks 1
 Share
