Undo if the user cancels while drawing temporary objects
I've looked up many threads on this but I was wondering if this is a good approach?
I have an error handler like this:
(defun *error* (errmsg)
  (and acDoc (vla-EndUndoMark acDoc))
  (and errmsg
    (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*"))
    (princ (strcat "\n<< Error: " errmsg " >>\n"))
  (if undoTempObjsBool
    (command-s "._undo" "" "")
Then in the code that I want to check if there's an undo while I draw some temp objects so that if the undoTempObjs variable is T then the undo action will work.
This works but I was wondering if there was a better way of handling this or am I on the right track?
  (setq undoTempObjsBool T)
  ;; Do some stuff here and afterwards set the undoTempObjsBool to nil
  (setq undoTempObjsBool nil)
Edited by 3dwannab
  • 3dwannab changed the title to Undo if the user cancels while drawing temporary objects
