jim78b Posted February 21 Share Posted February 21 I need a macro that load refedit command in silent to all blocks in the drawing and close them saving is possible plese? i have no experience in programming. Quote Link to comment Share on other sites More sharing options...
tombu Posted March 1 Share Posted March 1 You can only edit or refedit one block at a time. With no experience in programming you'd be better off explaining what you're trying to accomplish in the AutoLISP, Visual LISP & DCL forum. It's frustrating to watch four good programmers make 10 code attempts before figuring out what the poster actually needed. The refedit command while useful can cause more problems than the standard block editor if you forget you're in it and close the drawing for instance. If you think a macro will be the answer to your needs please explain what you're trying to do here. Quote Link to comment Share on other sites More sharing options...
