DeleteBlocksV1-1.lsp (lee-mac.com) no selection window.
Dear all,
Is it possible to run lisp (DeleteBlocksV1-1.lsp) by selecting all blocks without opening the popup window?
Select all without this window appearing.
;;  Author:  Lee Mac, Copyright © 2012  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2012-07-14                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2016-11-05                                      ;;
;;  - Program modified to prompt user for selection of a block to       ;;
;;    delete, with the option of displaying a list of all blocks        ;;
;;    defined in the drawing.                                           ;;
(defun c:delblocks ( / *error* def lst sel tmp )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
    (while (setq def (tblnext "block" (not def)))
        (if (zerop (logand 125 (cdr (assoc 70 def))))
            (setq lst (cons (cdr (assoc 2 def)) lst))
    (setq lst (vl-sort lst '<))
    (while
        (and (or lst (prompt "\nNo blocks defined in the current drawing."))
                (setvar 'errno 0)
                (initget "Name Exit")
                (setq sel (entsel "\nSelect block to delete [Name/Exit] <Exit>: "))
                (cond
                    (   (= 7 (getvar 'errno))
                        (princ "\nMissed, try again.")
                    (   (or (null sel) (= "Exit" sel))
                        nil
                    (   (= "Name" sel)
                        (if (setq tmp (LM:filtlistbox "Select Blocks to Delete" lst t))
                            (setq tmp (LM:deleteblocks:acdoc tmp)
                                  lst (vl-remove-if '(lambda ( x ) (member (strcase x) tmp)) lst)
                        nil
                    (   (/= "INSERT" (cdr (assoc 0 (entget (car sel)))))
                        (princ "\nThe selected object is not a block.")
                    (   t
                        (setq tmp (LM:deleteblocks:acdoc (list (LM:blockname (vlax-ename->vla-object (car sel)))))
                        t
(defun LM:deleteblocks:acdoc ( del / rtn )
    (LM:startundo (LM:acdoc))
    (setq rtn (LM:deleteblocks (LM:acdoc) del))
    (vla-regen (LM:acdoc) acallviewports)
    (foreach blk del
        (if (member (strcase blk) rtn)
            (princ (strcat "\nDeleted block " blk "."))
            (princ (strcat "\nUnable to delete block " blk "."))
    rtn
;; Delete Blocks  -  Lee Mac
;; Deletes all references of a list of blocks from a drawing (including nested references, nested to any level).
;; Proceeds to delete the associated block definitions from the drawing, if possible.
;; doc - [vla] Document object
;; lst - [lst] List of block names (case insensitive)
;; Returns: [lst] List of blocks that were successfully deleted.
(defun LM:deleteblocks ( doc lst / blc lck )
    (setq blc (vla-get-blocks doc))
    (if (setq lst (mapcar 'strcase (vl-remove-if-not '(lambda ( blk ) (LM:catchapply 'vla-item (list blc blk))) lst)))
            (vlax-for lay (vla-get-layers doc)
                (if (= :vlax-true (vla-get-lock lay))
                        (setq lck (cons lay lck))
                        (vla-put-lock lay :vlax-false)
            (vlax-for def blc
                (vlax-for obj def
                    (if (and (= "AcDbBlockReference" (vla-get-objectname obj))
                             (member (strcase (LM:blockname obj)) lst)
                        (vl-catch-all-apply 'vla-delete (list obj))
            (setq lst (vl-remove-if-not '(lambda ( blk ) (LM:catchapply 'vla-delete (list (vla-item blc blk)))) lst))
            (foreach lay lck (vla-put-lock lay :vlax-true))
            lst
;; Catch Apply  -  Lee Mac
;; Applies a function to a list of parameters and catches any exceptions.
(defun LM:catchapply ( fnc prm / rtn )
    (if (not (vl-catch-all-error-p (setq rtn (vl-catch-all-apply fnc prm))))
        (cond ( rtn ) ( t ))
;; Filtered List Box  -  Lee Mac
;; Displays a list box interface from which the user may select one or more items.
;; Includes an edit box filter to enable the user to filter the displayed list of items.
;; msg - [str] List box dialog title
;; lst - [lst] List of strings to display in the list box
;; mtp - [bol] T=Allow multiple items; nil=Single item selection
;; Returns: [lst] List of selected items, else nil
(defun LM:filtlistbox ( msg lst mtp / _addlist dch dcl des rtn sel tmp )
    (defun _addlist ( key lst )
        (start_list key)
        (foreach x lst (add_list x))
        (end_list)
        lst
    (if
        (and
            (setq dcl (vl-filename-mktemp nil nil ".dcl"))
            (setq des (open dcl "w"))
            (write-line
                (strcat
                    "filtlistbox : dialog { label = \"" msg "\"; spacer;"
                    ": list_box { key = \"lst\"; width = 50; fixed_width = true; height = 15; fixed_height = true; allow_accept = true; "
                    "multiple_select = " (if mtp "true" "false") "; }"
                    ": edit_box { key = \"flt\"; width = 50; fixed_width = true; label = \"Filter:\"; }"
                    "spacer; ok_cancel; }"
                des
            (not (close des))
            (< 0 (setq dch (load_dialog dcl)))
            (new_dialog "filtlistbox" dch)
            (_addlist "lst" (setq tmp lst))
            (set_tile "lst" (setq rtn "0"))
            (set_tile "flt" "*")
            (action_tile "lst" "(setq rtn $value)")
            (action_tile "flt"
                (vl-prin1-to-string
                   '(progn
                        (setq flt (strcat "*" (strcase $value) "*")
                              sel (mapcar '(lambda ( n ) (nth n tmp)) (read (strcat "(" rtn ")")))
                        (_addlist "lst" (setq tmp (vl-remove-if-not '(lambda ( x ) (wcmatch (strcase x) flt)) lst)))
                        (set_tile "lst"
                            (setq rtn
                                (vl-string-trim "()"
                                    (vl-princ-to-string
                                        (cond
                                            (   (vl-sort (vl-remove nil (mapcar '(lambda ( x ) (vl-position x tmp)) sel)) '<))
                                            (  '(0)   )
            (setq rtn
                (if (= 1 (start_dialog))
                    (mapcar '(lambda ( x ) (nth x tmp)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (setq dch (unload_dialog dch))
    (if (and (= 'str (type dcl)) (findfile dcl))
        (vl-file-delete dcl)
    rtn
;; Block Name  -  Lee Mac
;; Returns the true (effective) name of a supplied block reference
(defun LM:blockname ( obj )
    (if (vlax-property-available-p obj 'effectivename)
        (defun LM:blockname ( obj ) (vla-get-effectivename obj))
        (defun LM:blockname ( obj ) (vla-get-name obj))
    (LM:blockname obj)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns a global pointer to the VLA Active Document Object
(defun LM:acdoc nil
    (cond ( acdoc ) ((setq acdoc (vla-get-activedocument (vlax-get-acad-object)))))
(vl-load-com) (princ)
;;                             End of File                              ;;
Lee provides excellent code and like in most of his routines it is possible to bypass say the enter blocknames. You need to look at the sequence of events as the program steps through various defuns. The obvious not required if you have a block list
These 2 lines need to be modified as a minimum
You would provide the list tmp with the block names.
The best way would be to ask use a predefined list or select from dwg. Did you try to contact Lee about this.
I respect Lee's code so in this case will not try to modify.
Edited by BIGAL
Dear @BIGAL, thanks for the feedback, if it is possible, I would like to know to change the initial condition for all selected blocks.  if I need to delete all blocks just click “ok”.  Regards.
