How to copy the first Unselected element from a listBox to another in vb.net
Hello All,
I need code that helps me to copy the first Unselected element from a listBox to another, I already know how to copy all unselected elements as below but I need to copy just the first Element from the lisbox:
                    For i As Integer = 0 To ListBox3.Items.Count - 1
                       If ListBox3.GetSelected(i) Then
                            ListBox1.Items.Add(ListBox3.Items(i))
                        Else
                        End If
                    Next
thanks
  • 2 months later...
Usualy You can use Exit For, but then ..... hm, from Your's code items are copied from LB3 to LB1 no matter if they are selected or not.
Or you can use something like this:
DIm toCopy as Boolean
toCopy = true
itherate through list
if item is unselected and toCopy
     copy element
     toCopy = false
I am using c#, so VB(A) is somewhere between My ears..
Edited by goran
