On 3/17/2022 at 9:08 AM, BIGAL said:
exceed welcome to use this
Have you looked at ( setq colnum (acad_colordlg 1) pick any color probably what I would use saves need more defuns.
or
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(ah:butts but "V" '("Choose a color" "yellow" "green" "cyan" "blue" "magenta" "white" "gray" "light" "gray" "purple"))
; the variable BUT inside the code holds the button selected value can use that for this post
; make it color with dcl - 2022.03.18 exceed
; this lisp use object's hyperlink property
; command list
; mip - change color for all
; mips - change color for 1 selected object(blocks)
(defun c:mip ( / answer )
; Multi button Dialog box for a single choice repalcment of initget
; By Alan H Feb 2019
; Example code as the radio button click will close the default button setting is required
; if you have defined a default setting
; (if (not AH:Butts)(load "Multi radio buttons.lsp")) 			; loads the program if not loaded already
; (if (= but nil)(setq but 1)) 						; this is needed to set default button
									; you can reset default button to user pick
; (setq ans (ah:butts but "V"   '("A B C D " "A" "B" "C" "D" ))) 	; ans holds the button picked value as a string
									; if you want ans a number use (atof ans) or (atoi ans)
; (if (not AH:Butts)(load "Multi Radio buttons.lsp"))
; (setq ans (ah:butts but "h"  '("Yes or No" "Yes" "No"))) ; ans holds the button picked value
; (setq ans (atoi(ah:butts but "V" '("Choose a number" "1" "2" "3" "4" "5" "6" "7" "8" "9" "10")))) ; ans holds the button picked as an integer value
(vl-load-com)
(defun AH:Butts (AHdef verhor butlst / fo fname x  k )
(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
(write-line  "AHbutts : dialog 	{" fo)
(write-line  (strcat "	label =" (chr 34) (nth 0 butlst) (chr 34) " ;" )fo)
(write-line "	: row	{" fo)
(if (=  (strcase verhor) "V")
(write-line "	: boxed_radio_column 	{" fo)
(write-line  (strcat " width = " (rtos (+ (strlen (nth 0 butlst)) 15) 2 0) " ;")  fo)		; increase 10 if label does not appear
(write-line "	: boxed_radio_row	{" fo)
(setq x 1)
(repeat (- (length butlst) 1)
(write-line "	: radio_button	{" fo)
(write-line  (strcat "key = "  (chr 34) "Rb" (rtos x 2 0)  (chr 34) ";") fo)
(write-line  (strcat "label = " (chr 34) (nth x  butlst) (chr 34) ";") fo)
(write-line "	}" fo)
;(write-line "spacer_1 ;" fo)
(setq x (+ x 1))
(write-line "	ok_only;" fo)
(close fo)
(setq dcl_id (load_dialog fname))
(if (not (new_dialog "AHbutts" dcl_id) )
(exit)
(setq x 1)
(setq k (strcat "Rb" (rtos x 2 0)))
(action_tile k  (strcat "(setq but "  (rtos x 2 0) ")" "(done_dialog)"))
(if (= ahdef x)(set_tile k "1"))
(setq x (+ x 1))
(set_tile "Rb1" "1")
(action_tile "accept" (strcat "(setq but "  (rtos ahdef 2 0) ")" "(done_dialog)"))
(start_dialog)
(unload_dialog dcl_id)
(vl-file-delete fname)
(nth but butlst)
  (setq answer (ah:butts but "V" '("Choose a color for all" "return-to-origin" "red" "yellow" "green" "cyan" "blue" "magenta" "white" "gray" "lightgray" "gray" "purple")))
; (princ answer)
  (cond
    ((= answer "return-to-origin") (ex:mic))
    ((= answer "red") (ex:mip 1))
    ((= answer "yellow") (ex:mip 2))
    ((= answer "green") (ex:mip 3))
    ((= answer "cyan") (ex:mip 4))
    ((= answer "blue") (ex:mip 5))
    ((= answer "magenta") (ex:mip 6))
    ((= answer "white") (ex:mip 7))
    ((= answer "gray") (ex:mip 8))
    ((= answer "lightgray") (ex:mip 9))
    ((= answer "purple") (ex:mip 200))
  );end of cond
(defun c:mips ( / answer )
(vl-load-com)
(setq x 1)
(setq x (+ x 1))
(close fo)
(exit)
(setq x 1)
(setq x (+ x 1))
(start_dialog)
(nth but butlst)
  (setq answer (ah:butts but "V" '("Choose a color for one" "return-to-origin" "red" "yellow" "green" "cyan" "blue" "magenta" "white" "gray" "lightgray" "gray" "purple")))
; (princ answer)
  (cond
    ((= answer "return-to-origin") (ex:mics))
    ((= answer "red") (ex:mips 1))
    ((= answer "yellow") (ex:mips 2))
    ((= answer "green") (ex:mips 3))
    ((= answer "cyan") (ex:mips 4))
    ((= answer "blue") (ex:mips 5))
    ((= answer "magenta") (ex:mips 6))
    ((= answer "white") (ex:mips 7))
    ((= answer "gray") (ex:mips 8))
    ((= answer "lightgray") (ex:mips 9))
    ((= answer "purple") (ex:mips 200))
  );end of cond
(vl-load-com)
(defun ex:mip ( setcolor / blkss blk ent edata blknames setcolor_txt c_lyrs lock_lst *error* ss ssl index obj color linetype linetypescale str en check index1 obj1 en1 ssblk ssblkindex blkent blk ent enx obj2 color2 linetype2 linetypescale2 str2 hlinks2 )
   (setvar 'cmdecho 0)
   (LM:startundo (LM:acdoc))
    (defun *error* ( msg )
        (rh:relock_lyrs lock_lst)
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\n Error: " msg))
        (setvar 'cmdecho 1)
  (setq c_lyrs (vla-get-layers (LM:acdoc)))
  (setq lock_lst (rh:lock_lyr_list c_lyrs))
  (rh:unlock_lyrs lock_lst)
 (cond
   ((= setcolor 1) (setq setcolor_txt "red") )
   ((= setcolor 2) (setq setcolor_txt "yellow") )
   ((= setcolor 3) (setq setcolor_txt "green") )
   ((= setcolor 4) (setq setcolor_txt "cyan") )
   ((= setcolor 5) (setq setcolor_txt "blue") )
   ((= setcolor 6) (setq setcolor_txt "magenta") )
   ((= setcolor 7) (setq setcolor_txt "white") )
   ((= setcolor 8) (setq setcolor_txt "gray") )
   ((= setcolor 9) (setq setcolor_txt "lightgray") )
   ((= setcolor 200) (setq setcolor_txt "purple") )
 );end of cond
 (princ "\n make it ")
 (princ setcolor_txt)
 (princ " - processing ")
 (if (setq ss (ssget "X"))
      (setq ssl 0)
      (setq ssl (sslength ss))
      (setq index 0)
      (setq str "")
      (repeat ssl
        (setq en (ssname ss index))
        (setq obj (vlax-ename->vla-object (cdr (assoc -1 (entget en)))))
        ;(vlax-for x (vla-get-hyperlinks obj) (vla-delete x))
        (setq old_str "")
        (vlax-for each (vlax-get-property obj 'Hyperlinks)
            (setq old_str (strcat (vla-get-url each)))
          ;(princ "\n old_str - ")
          ;(princ old_str)
        (if (/= (substr old_str 1 3) "MIP")
        ;(princ "\n modify")
        (setq color (vl-princ-to-string (vla-get-color obj)))
        (setq linetype (vl-princ-to-string (vla-get-linetype obj)))
        (setq linetypescale (vl-princ-to-string (vla-get-linetypescale obj)))
        (setq str (strcat "MIP/" color "/" linetype "/" linetypescale))
        (setq hlinks (vlax-get-property obj 'Hyperlinks))
        (vla-add hlinks str)
        ;(princ "\n stay")
        (vla-add (vlax-get-property obj 'Hyperlinks) old_str)
        (setq index (+ index 1))
      );end of repeat
      (setq index1 0)
      (repeat ssl
        (setq en1 (ssname ss index1))
        (setq obj1 (vlax-ename->vla-object (cdr (assoc -1 (entget en1)))))
        (setq check (vlax-property-available-p obj1 "Color" T))
	(if check
		(vlax-put-property obj1 'Color setcolor)
        (vla-put-linetype obj1 "continuous")
        (vla-put-linetypescale obj1 1)
        (setq index1 (+ index1 1))
      );end of repeat
    );end of progn
  );end of if
(if (setq blkss (ssget "x" '((0 . "insert")) ))
    (repeat (setq inc (sslength blkss)); get names from initial selection
      (setq blk (ssname blkss (setq inc (1- inc))))
      (nametolist blk)
    ); repeat
  (while (setq blk (car blknames)); as long as there's another Block name in list
    ;; [done this way instead of via (repeat) or (foreach), so it can add nested Blocks' names to the list]
    (setq ent (tblobjname "block" blk)); Block definition as entity
    (while (setq ent (entnext ent)); then -- proceed through sub-entities in definition
      (setq edata (entget ent))
      (if (member '(0 . "INSERT") edata) (nametolist ent)); if nested Block, add name to end of list
        (setq obj (vlax-ename->vla-object ent))
        (setq old_str "")
          ;(princ old_str)
          );end of progn
           ;(princ "\n stay")
          );end of progn
        );end of if
        (if (vlax-property-available-p obj 'Linetype)
         	 (vla-put-linetype obj "continuous")
        (vla-put-color obj setcolor); color ByLayer
    ); while -- sub-entities
    (setq blknames (cdr blknames)); take first one off
  ); while
);end of progn
);end of if
(vla-regen (LM:acdoc) acallviewports)
(princ " - complete!")
(setvar 'cmdecho 1)
);end of defun
;mip for single selection
(defun ex:mips ( setcolor / blkss blk ent edata blknames setcolor_txt c_lyrs lock_lst *error* ss ssl index obj color linetype linetypescale str en check index1 obj1 en1 ssblk ssblkindex blkent blk ent enx obj2 color2 linetype2 linetypescale2 str2 hlinks2 )
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
 (cond
 );end of cond
 (if (setq ss (ssget ":S"))
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
        (setq old_str "")
          ;(princ old_str)
        ;(princ "\n stay")
      );end of repeat
      (setq index1 0)
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
(if (setq blkss (ssget "P" '((0 . "insert")) ))
      (nametolist blk)
    ); repeat
        (setq old_str "")
          ;(princ old_str)
          );end of progn
           ;(princ "\n stay")
          );end of progn
        );end of if
  ); while
);end of progn
);end of if
(setvar 'cmdecho 1)
);end of defun
(defun ex:mic ( / blkss blk ent edata blknames c_lyrs lock_lst *error* ssblk ssblkl ssblkindex blk ent enx str2 obj2 hlinks2 strlist2 color2 linetype2 linetypescale2 check ss ssl index obj color linetype linetypescale str layertable newlayername en check strlist )
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
(princ "\n make it color (return to origin) - processing ")
      (nametolist blk)
    ); repeat
        (setq obj2 (vlax-ename->vla-object ent))
        (setq str2 "")
        (setq hlinks2 (vlax-get-property obj2 'Hyperlinks))
        (vlax-for each hlinks2
            (setq str2 (strcat (vla-get-url each)))
        (if (/= str2 "")
            (setq strlist2 '())
            (setq strlist2 (LM:str->lst str2 "/"))
            (setq color2 (cadr strlist2))
            (setq linetype2 (caddr strlist2))
            (setq linetypescale2 (nth 3 strlist2))
            (setq check (vlax-property-available-p obj2 "Color" T))
               (if check
   	     (vlax-put-property obj2 'Color color2)
            (vla-put-linetype obj2 linetype2)
            (vla-put-linetypescale obj2 linetypescale2)
            (vlax-for x (vla-get-hyperlinks obj2) (vla-delete x))
          ); end of progn
        );end of if
  ); while
);end of progn
);end of if
 (if (setq ss (ssget "X" '((-3 ("PE_URL")))))
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
          (setq str (strcat (vla-get-url each)))
        (setq strlist (LM:str->lst str "/"))
        (setq color (cadr strlist))
        (setq linetype (caddr strlist))
        (setq linetypescale (nth 3 strlist))
        (setq check (vlax-property-available-p obj "Color" T))
	(if check
		(vlax-put-property obj 'Color color)
        (vla-put-linetype obj linetype)
        (vla-put-linetypescale obj linetypescale)
      );end of repeat
    );end of progn
  );end of if
(princ "\n make it color (return to origin)")
(setvar 'cmdecho 1)
);end of defun
;mic for single selection
(defun ex:mics ( / ssorigin blkss blk ent edata blknames c_lyrs lock_lst *error* ssblk ssblkl ssblkindex blk ent enx str2 obj2 hlinks2 strlist2 color2 linetype2 linetypescale2 check ss ssl index obj color linetype linetypescale str layertable newlayername en check strlist )
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
(setq ssorigin (ssget ":s"))
      (nametolist blk)
    ); repeat
        (setq str2 "")
        (if (/= str2 "")
            (setq strlist2 '())
               (if check
          ); end of progn
        );end of if
  ); while
);end of progn
);end of if
(command "_.SELECT" ssorigin "")
 (if (setq ss (ssget "P" '((-3 ("PE_URL")))))
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
(setvar 'cmdecho 1)
);end of defun
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; String to List  -  Lee Mac
;; Separates a string using a given delimiter
;; str - [str] String to process
;; del - [str] Delimiter by which to separate the string
;; Returns: [lst] List of strings
(defun LM:str->lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/create-list-of-locked-layers-lock-amp-unlock-again/m-p/9306234/highlight/true#M395697
;; unlock all layers : requires list of locked layer objects
(defun rh:unlock_lyrs (lst)
  (mapcar '(lambda (x) (vlax-put-property x 'lock :vlax-false)) lst)
);end_defun
;; relock all previously locked layers : requires list of locked layer objects
(defun rh:relock_lyrs (lst)
  (mapcar '(lambda (x) (vlax-put-property x 'lock :vlax-true)) lst)
);end_defun
;return list of locked layer objects : requires layer collection
(defun rh:lock_lyr_list (lyrs / lst)
  (if (= "AcDbLayerTable" (vlax-get-property lyrs 'objectname))
    (vlax-map-collection lyrs  '(lambda (x) (if (= :vlax-true (vlax-get-property x 'lock)) (setq lst (cons x lst)))))
  );end_if
  lst
);end_defun
;;  BlockSParts0Bylayer.lsp
;;  = change all Parts of definitions of Selected Block(s) [other
;;    than on Layer Defpoints] to Layer 0 with Color ByLayer
;;  Kent Cooper, 3 November 2014
;; Modified by Alan h OCT 2020
;; now does linetype only
  (defun nametolist (blk / blkobj blkname); get Block name and put it into list of names
    (if (= (logand (cdr (assoc 70 (entget blk))) 4) 0) ; not an Xref
        (setq
          blkobj (vlax-ename->vla-object blk)
          blkname
            (vlax-get-property blkobj
              (if (vlax-property-available-p blkobj 'EffectiveName) 'EffectiveName 'Name)
                ; to work with older versions that don't have dynamic Blocks
            ); ...get-property & blkname
        ); setq
        (if
          (not (member blkname blknames)); name not already in list
          (setq blknames (append blknames (list blkname))); then -- add to end of list
        ); if
      ); progn
    ); if
  ); defun -- nametolist
(princ "\n make it color - loading complete")
I applied your Multi radio buttons.lsp to this routine. thank you for your help.
Since it is 1 column, the command is divided into mip and mips.
If I use dcl well, I think I can make a better Lisp. Lisp is something new to learn every day.
success to 2 column!
My duct tape modifications made it no longer a generally available module, but it was nice to be able to study dcl.
; command list
; mic - change color for all or one
(defun c:mic ( / answer )
; (setq ans (atoi(ah:butts but '("Choose a number" "1" "2" "3" "4" "5" "6" "7" "8" "9" "10")))) ; ans holds the button picked as an integer value
(vl-load-com)
(defun AH:Butts (AHdef butlst / fo fname x  k )
(write-line (strcat "key = " (chr 34) "For ALL" (chr 34) ";") fo)
(write-line (strcat "label = " (chr 34) "For ALL" (chr 34) ";") fo)
(setq x 1)
(repeat 12
(setq x (+ x 1))
(write-line (strcat "key = " (chr 34) "For ONE" (chr 34) ";") fo)
(write-line (strcat "label = " (chr 34) "For ONE" (chr 34) ";") fo)
(repeat 12
(setq x (+ x 1))
(close fo)
(exit)
(setq x 1)
(repeat 24
(setq x (+ x 1))
(start_dialog)
(nth but butlst)
  (setq answer (ah:butts but '("MIC - Choose a color" "return-to-origin" "red" "yellow" "green" "cyan" "blue" "magenta" "white" "gray" "lightgray" "gray" "purple" "return-to-origin1" "red1" "yellow1" "green1" "cyan1" "blue1" "magenta1" "white1" "gray1" "lightgray1" "gray1" "purple1")))
; (princ answer)
  (cond
    ((= answer "return-to-origin1") (ex:mics))
    ((= answer "red1") (ex:mips 1))
    ((= answer "yellow1") (ex:mips 2))
    ((= answer "green1") (ex:mips 3))
    ((= answer "cyan1") (ex:mips 4))
    ((= answer "blue1") (ex:mips 5))
    ((= answer "magenta1") (ex:mips 6))
    ((= answer "white1") (ex:mips 7))
    ((= answer "gray1") (ex:mips 8))
    ((= answer "lightgray1") (ex:mips 9))
    ((= answer "purple1") (ex:mips 200))
  );end of cond
(vl-load-com)
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
 (cond
 );end of cond
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
        (setq old_str "")
          ;(princ old_str)
        ;(princ "\n stay")
      );end of repeat
      (setq index1 0)
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
      (nametolist blk)
    ); repeat
        (setq old_str "")
          ;(princ old_str)
          );end of progn
           ;(princ "\n stay")
          );end of progn
        );end of if
  ); while
);end of progn
);end of if
(setvar 'cmdecho 1)
);end of defun
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
 (cond
 );end of cond
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
        (setq old_str "")
          ;(princ old_str)
        ;(princ "\n stay")
      );end of repeat
      (setq index1 0)
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
      (nametolist blk)
    ); repeat
        (setq old_str "")
          ;(princ old_str)
          );end of progn
           ;(princ "\n stay")
          );end of progn
        );end of if
  ); while
);end of progn
);end of if
(setvar 'cmdecho 1)
);end of defun
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
      (nametolist blk)
    ); repeat
        (setq str2 "")
        (if (/= str2 "")
            (setq strlist2 '())
               (if check
          ); end of progn
        );end of if
  ); while
);end of progn
);end of if
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
(setvar 'cmdecho 1)
);end of defun
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
      (nametolist blk)
    ); repeat
        (setq str2 "")
        (if (/= str2 "")
            (setq strlist2 '())
               (if check
          ); end of progn
        );end of if
  ); while
);end of progn
);end of if
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
(setvar 'cmdecho 1)
);end of defun
(defun LM:acdoc nil
    (LM:acdoc)
    (LM:endundo doc)
        (list str)
);end_defun
);end_defun
  );end_if
  lst
);end_defun
        (setq
          blkname
        ); setq
        (if
        ); if
      ); progn
    ); if
Edited by exceed
I don't think I'll ever learn to code. it's difficult.
i tried it thanks but in my case don't return in original state. have good day
For Exceed 2 columns just never posted it. I was going to make a new multi radio buttons that could have as many columns as you like so a list of lists approach 1 -> a practical limit.
The other thing I think its in Multi getvals if only a few items has double spacing could add also to radio buttons.
(cond
(cond
    ((= but 1) (ex:mic))
    ((= but 2) (ex:mip 1))
    ((= but 3) (ex:mip 2))
Multi radio buttons 2col.lsp
Edited by BIGAL
It Is a good lisp, but i am sad because is terribly slow 😥.
Faster than doing it yourself?
  • Dislike 1
I don't understand this arrogance. I always thanks and be kind.
It is not an arrogance, everyone always appreciates praise when they have helped - which you do do. Maybe I took your comment the wrong way - as a thanks but also a criticism - perhaps lost the meaning with the typed word on the screen - which is the basis of my comment - it is better than doing it all manually.
  • Agree 1
  • 7 months later...
sorry , your lisp works!!! today I realized that it works, but every time I press a command es 1,2,3,4,5 then I have to press esc because if not it stops, can you please change the lisp so that it works? thank you
; make it color - 2022.03.15 exceed
; command list
; ` = make it color (return to origin) leftside of "1" key
; 1 = make it red
; 2 = make it yellow
; 3 = make it green
; 4 = make it cyan
; 5 = make it blue
; 6 = make it magenta
; 7 = make it white
; 8 = make it gray
; 9 = make it light gray
; 0 = make it purple
(defun c:` () (ex:mic) (princ)) ;make it color (return to origin)
(defun c:1 () (ex:mip 1) (princ)) ;make it red
(defun c:2 () (ex:mip 2) (princ)) ;make it yellow
(defun c:3 () (ex:mip 3) (princ)) ;make it green
(defun c:4 () (ex:mip 4) (princ)) ;make it cyan
(defun c:5 () (ex:mip 5) (princ)) ;make it blue
(defun c:6 () (ex:mip 6) (princ)) ;make it magenta
(defun c:7 () (ex:mip 7) (princ)) ;make it white
(defun c:8 () (ex:mip 8) (princ)) ;make it gray
(defun c:9 () (ex:mip 9) (princ)) ;make it lightgray
(defun c:0 () (ex:mip 200) (princ)) ;make it purple
(vl-load-com)
(defun ex:mip ( setcolor / setcolor_txt c_lyrs lock_lst *error* ss ssl index obj color linetype linetypescale str en check index1 obj1 en1 ssblk ssblkindex blkent blk ent enx obj2 color2 linetype2 linetypescale2 str2 hlinks2 )
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
 (cond
 );end of cond
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
        (setq old_str "")
          ;(princ old_str)
        ;(princ "\n stay")
      );end of repeat
      (setq index1 0)
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
(if (setq ssblk (ssget "x" '((0 . "insert")) ))
    (setq ssblkl (sslength ssblk))
    (setq ssblkindex 0)
    (repeat ssblkl
      (setq blkent (entget (ssname ssblk ssblkindex)))
      (setq blk (cdr (assoc 2 blkent)))
      (if (setq ent (tblobjname "BLOCK" blk))
        (while (and (setq ent (entnext ent)))
          (setq enx (entget ent))
          (setq obj2 (vlax-ename->vla-object (cdr (assoc -1 enx))))
          ;(vlax-for x (vla-get-hyperlinks obj2) (vla-delete x))
          (setq old_str2 "")
          (vlax-for each (vlax-get-property obj2 'Hyperlinks)
            (setq old_str2 (strcat (vla-get-url each)))
          ;(princ "\n old_str2 - ")
          ;(princ old_str2)
        (if (/= (substr old_str2 1 3) "MIP")
            (setq color2 (vl-princ-to-string (vla-get-color obj2)))
            (setq linetype2 (vl-princ-to-string (vla-get-linetype obj2)))
            (setq linetypescale2 (vl-princ-to-string (vla-get-linetypescale obj2)))
            (setq str2 (strcat "MIP/" color2 "/" linetype2 "/" linetypescale2))
            (vla-add hlinks2 str2)
          ;(princ "\n stay")
          (vla-add (vlax-get-property obj2 'Hyperlinks) old_str2)
        );end of while
      );end of progn
    );end of if
    (setq ssblkindex (+ ssblkindex 1))
   );end of repeat
    (setq ssblkindex 0)
    (repeat ssblkl
  	(if check
		(vlax-put-property obj2 'Color setcolor)
          (vla-put-linetype obj2 "continuous")
          (vla-put-linetypescale obj2 1)
        );end of while
      );end of progn
    );end of if
   );end of repeat
);end of progn
);end of if
(setvar 'cmdecho 1)
);end of defun
(defun ex:mic ( / c_lyrs lock_lst *error* ssblk ssblkl ssblkindex blk ent enx str2 obj2 hlinks2 strlist2 color2 linetype2 linetypescale2 check ss ssl index obj color linetype linetypescale str layertable newlayername en check strlist )
   (setvar 'cmdecho 0)
        (setvar 'cmdecho 1)
    (setq ssblkindex 0)
    (repeat ssblkl
          (setq str2 "")
          (if (/= str2 "")
               (setq strlist2 '())
               (if check
             ); end of progn
           );end of if
        );end of while
      );end of progn
    );end of if
   );end of repeat
);end of progn
);end of if
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
	(if check
      );end of repeat
    );end of progn
  );end of if
(setvar 'cmdecho 1)
);end of defun
(defun LM:acdoc nil
    (LM:acdoc)
    (LM:endundo doc)
        (list str)
);end_defun
);end_defun
  );end_if
  lst
);end_defun
(princ "\n command [ ` - return / 1 - red / 2 - yellow / 3 - green / 4 - cyan / 5 - blue / 6 - magenta / 7 - white / 8 - gray / 9 - light gray / 0 - purple ]")
