Good Afternoon
Can anyone Help ?
AutoCad 2009
I am rendering (using rendercrop command in model space) a conveyor which i am adding different materials to components in seperate layers. so far so good.
After i have applied materials to one layer (say red plastic to skate wheels layor) i would then test the render by using rendercrop before adding any other materials to the other layers.
when i am happy with the render of the skate wheels layer i turn this layer off
and then add materials to the next layer (say grey painted steel to the frame work layer) . Now i want to test the render of this layer, so i use rendercrop,
the problem is that the render still remembers the first render of the skate wheels layer (which is turned off) but ignores the frame work layer i have just added materials too.
Hope this makes sense.
Hi Cad64
just going to try freezing the layer
but before that i tried rendercrop again when opening a
drawing , it rendered ok the first time, so i zoomed in and used rendercrop again
- No faces to render - appears
The scene ontains no renderable geometry , rendering aborted
Not sure if these problems are linked and due to layers
Have you come across this before ?
I Was Working In 2d Wireframe Style On A 3d Drawing
Should Of Been In A 3d Environment To Create Renderings.
Feel A Bit Of A Idiot.
Thanks
Alan
