Markgyver Posted February 13, 2009 Posted February 13, 2009 We have a bunch of drawings that were bound. When you bind the drawings it adds the xref name to the layer name. Is there a lisp that will remove the xref name and combine multiple layers with the same name? Quote
lpseifert Posted February 13, 2009 Posted February 13, 2009 Try this, works on more than layer names though, read the header. If there are already layers with the same name as the bound layers, they won't be renamed. I can't take credit; thanks to the unknown author RemoveBindPrefixes.lsp Quote
Dipali Posted February 14, 2009 Posted February 14, 2009 to avoid these steps in future projects, use bind>insert option while binding x-ref's & than you can explode it if you don't like it as block. but by suing 'insert' option it will murge x-ref's layers with current drawings similar named layers. Quote
Markgyver Posted February 17, 2009 Author Posted February 17, 2009 Dipali I am well aware of Bind Insert. The problem when you do Bind Insert, is that the detail that is Inserted takes on the Dim/Text perameters of the drawing. So Bind Insert does not work In all cases Quote
