[lisp] lengthening, shortening according to the center of the line
Noodles
 Share
Hi !,
I wrote a lisp that allows you to lengthen or shorten the line on both sides by the given amount. Is it possible to modify this lisp to lengthen / shorten a given line to the given value, e.g. 3.5, 4 etc. relative to the center of this line? E.g Line length 2.35 -> extend it to length 2.50 on both sides with one command
(defun c:df ( / ss en a)
  (if (and (setq ss (ssget "_+.:E:S" '((0 . "LINE"))))
	   (setq en (ssname ss 0)))
    (command "_.LENGTHEN"
	     "_DE"
	     ;(setq a (getreal "\nO ile: "))
(setq *rev*
   (lambda ( input ) (if (eq "" input) *rev* input))
   (getstring (strcat "\nEnter Revision Number <" (setq *rev* (cond ( *rev* ) ( "1" ))) "> : "))
	     (list en (trans (cdr (assoc 10 (entget en))) 0 1))
	     (list en (trans (cdr (assoc 11 (entget en))) 0 1))
For that you'd need to use the "_.SCALE" command "Reference" option in the code using the calculated distance between the endpoints.
Actually with that lisp you could lengthen from midpoint or either end so it would work for all you lengthen line work.
Edited by tombu
"I wrote a lisp"
your new lisp
entsel line
get the start and end points
get angle of start -
end
mid point (setq mp (mapcar '* (mapcar '+ start end) '(0.5 0.5)))
use polar new end with new dist
use polar new start
use entmod on dxf 10 & 11
Edited by BIGAL
 Share
