Linking Block Visibility State to Object Field data?
Sambo
Hello,
I'm wondering if its possible to create a lisp or something that would link a scale bar controlled by block visibility states to a user selected viewport and have the visibility state of the block be controlled by that viewports object field data? (specifically the custom scale field).
I know how to read and set visibility states.
Could you upload an example?
Object Field data are a bit of a distant, vague memory to me.
  • 2 months later...
If you have the dynamic block with all your "CORRECT" scales then yes you can click on a viewport and insert block with correct visibility set. It looks like you know about CUSTOMSCALE.
Your 1st step is make the dynamic block with the multiple vis states.
2nd is get a copy of Lee-macs dynamic block lisp.
3rd the answer is in Lee's code. LM:SetVisibilityState
Last comment its not a field answer but could be automated to look through layouts.
