Export Link?
Can you export a link to an Excel file in the way that you import a link from an Excel file?
For instance, could you do a attribute/data extraction from a .dwg where the Excel file would be linked to said attributes/data so that if you update it in the .dwg it will automatically update in the Excel file?
If not, could you create a table in your .dwg that would have fields that are linked to the objects (attributes/data)?
I'm thinking in terms of a drainage structure table that would have structure numbers, grate elevations, pipe inverts, etc.
It might get a little complex I guess when adding and/or removing structures.
I answered my own question I think with creating the table in the .dwg. Automating it some might be a different question though.
