Move objects in Model space and re-align multiple viewports?
ILoveMadoka
 Share
Didn't want to cross post but was wondering if anyone knows of a lisp solution to a question I posted here:
My Question
I didn't want to approach this issue from a programming standpoint if Autocad has a solution.
I ask here in case the regulars in this forum don't look in the other forums..
If this is still considered cross posting, my apologies...
Edited by ILoveMadoka
If you activate the view ports it will zoom the the same location. I don't know if it will work if your in TOP and use it on SIDE or ISO view.
;; Zoom Area Across Multiple Drawings
(defun C:ZAD (/ a)  ;Zoom Across Drawings
  (initget "Yes No")
  (setq a
    (cond
      ((getkword "\nRedefine Zoom Area? [Yes/No]: ")) ( "No")
  (if (= "Yes" a)
      (vl-cmdf "_.Zoom" "W" Pause Pause)
      (setq vc (getvar 'viewctr))
      (setq SZ (getvar 'viewsize))
      (vl-propagate 'vc)
      (vl-propagate 'sz)
    (if vc sz
      (vl-cmdf "_.Zoom" "C" VC SZ)
      (prompt "\nPlease Define Zoom Area")
Edited by mhupp
Believe it or not but I am Kenny Ramage.
I cannot believe that AfraLisp is still having an influence.
  • Like 5
  • Thanks 1
Thanks for helping so many of us get started!
  • Like 2
Why? Clear easy to follow steps by step instructions. who wouldn't find that helpful.
If the objects in the model space are being moved without changing the scale or rotation, then I use this to change (pan) viewports view in all layouts or current layout only: VPML
 Share
