Jim Clayton Posted June 15 Share Posted June 15 Hello. I recently switched companies and I'm looking for a good title block template. The one that I was using got left behind with my previous company. So far everything I've seen online either has waaaaaay too much stuff in it or not enough and I'm not liking the templates that are pre-loaded into AutoCad. If anyone has any that they're willing to share, I'd greatly appreciate it. Tks. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 15 Share Posted June 15 (edited) Its really about you making the template it should have all your text styles, a title block that suits you, just add attributes to suit, linetypes including custom ones. My old dwt for instance for civ3D had like 200 layers, description keys, 100 Blocks and so on. So we had custom purge scripts ran after importing field survey. So removed unwanted objects. Our Surveyors had like 12 different layouts as they contained state survey forms. Edited June 15 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
tombu Posted June 16 Share Posted June 16 I have a few basic templates that include blocks, styles, layers and layer states we use for all our drawings. Everything else like page setups, layouts with title blocks and additional text & dimension styles are imported using Lee Mac's Steal from Drawing macros. Too many sizes & types of layouts & title blocks to include them all in a new drawing from a template. 2 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 17 Share Posted June 17 Forgot to add just take a existing drawing as a start and erase all objects but dont do a purge and add more to it, like Tombu use Lee's steal. 3 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 17 Share Posted June 17 What has all of that have to do with a Title Block Template? I didn't see the request for Drawing Templates. Back on topic, it would be near impossible to give you a Title Block to suit your needs without knowing what those needs would be. I have several different Title Blocks for different types and sizes of drawings. Each one designed to meet specific needs. It is pretty easy to make one. If you need specific help, just ask. 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 17 Share Posted June 17 If your going to start from scratch here is a little trick to get the maximum print area. Once the page size is set create a viewport and use the fit option. This creates a viewport on the dashed lines in paper space. (the maximum print area) You now have something to snap to when drawing a rectangle. That rectangle will need to be offset in a small distance. Then just delete the viewport and larger rectangle. you can now create a title block within said rectangle. 2 Quote Link to comment Share on other sites More sharing options...
nukecad Posted June 17 Share Posted June 17 On 15/06/2022 at 17:43, Jim Clayton said: .... I'm not liking the templates that are pre-loaded into AutoCad. If anyone has any that they're willing to share, I'd greatly appreciate it. Tks. Don't know if you want metric or imperial, but I uploaded a zip with a full set of metric ones some years ago: https://www.cadtutor.net/forum/topic/62352-titleblock/?tab=comments#comment-514547 3 Quote Link to comment Share on other sites More sharing options...
Jim Clayton Posted Friday at 03:10 PM Author Share Posted Friday at 03:10 PM Thanks to everyone for the replies. Sifting thru all of this now. I think I should be able to come up with something using some of this. Appreciate all of the help. Tks. Quote Link to comment Share on other sites More sharing options...
