Help lisp set color for polyline based on elevation
tuantrinhdp
 Share
Hello everyone. I have this problem and need help writing lisp, i want to choose color for polyline based on elevation.
Example:
- Polyline have elevation: 0.5,1.5,2.5,3.5,4.5,5.5,6.5,7.5,8.5,.... i want to set color ( ex: color green)
- Polyline have elevation: 1,2,3,4,6,7,8,9,11,12,13,14,16,17,18,19,21.... i want to set color ( ex: color megenta)Capture.png
test.dwg
Are all the polylines whole numbers (1 2 etc, not 1.34) and are they all 2d Polylines, not 3D?
Second question is what are your abilities to write a LISP like? For example if we gave you a couple of hints would you be able to write this or would you need a nearly complete LISP to do the job
Third question, did you search this forum? I am sure I saw similar in the last 2 or 3 months asking the same thing which can be a good starting point to modify7 to what you want.
there will of course be someone out there with this as a complete solution, you might get lucky that they post you an answer with that as well
-EDIT with the link:-
I reckon if you look at this and change the line "(Command "Pline".... " to change the colour that might work but CAD is off today, Sunday you see so I can't check for you
Edited by Steven P
You would need to set major contour interval, minor contour interval, as the plines do have a Z its feasible, I will say though never had to do it multicoloured in like 40 years. So a bit one off. Will maybe try to find time.
; ELPOLY - 2022.06.20 exceed
; https://www.cadtutor.net/forum/topic/75461-help-lisp-set-color-for-polyline-based-on-elevation/
; change lwpolyline's color by it's elevation
; 0, 5, 10, 15, 20... - change to red
; 1, 2, 3, 4, 5, 6, 7... - change to purple
; 1.5, 2.5, 3.5, 4.5, 5.5 ... - change to green
; 1.xxx, 2.xxx, 3.xxx ..... - change to green anyway
; if you want to change 4th option, just change
;         (t
;            (princ " , so change to green anyway")
;            (vlax-put-property obj 'color 3)
; "3" of this part's after 'color.
; this is autocad indexed color number
(vl-load-com)
(defun c:ELPOLY ( / ss ssl index obj objelevation )
  (if (setq ss (ssget ":L" '((0 . "LWPOLYLINE"))))
      (setq ssl (sslength ss))
      (setq index 0)
      (repeat ssl
        (setq obj (vlax-ename->vla-object (ssname ss index)))
        (setq objelevation (vlax-get-property obj 'elevation))
        (princ "\n it's elevation is = ")
        (princ objelevation)
        (cond
          ((= (rem objelevation 5) 0)
            (princ " , so change to red")
            (vlax-put-property obj 'color 1)
          ((= (rem objelevation 1) 0)
            (princ " , so change to purple")
            (vlax-put-property obj 'color 6)
          ((= (rem objelevation 0.5) 0)
            (princ " , so change to green")
          (t
        (setq index (+ index 1))
      (princ "\n there's nothing to change")
you can start with this
Edited by exceed
  • Thanks 1
A quick modification to the link I posted, Same result, slightly different method to exceed - though a blatant copy here for the 'cond' part of his code.
(defun c:layerElev ( / ss i pline elevation MyColour)
  (setq ss (ssget '((0 . "LWPOLYLINE"))))
  (if ss
      (setq i -1)
      (repeat (sslength ss)
        (setq i (1+ i)
              pline (ssname ss i)
              elevation (cdr (assoc 38 (entget pline)))
        (cond
          ((= (rem elevation 5) 0)(setq MyColour 1))
          ((= (rem elevation 1) 0)(setq MyColour 2))
          ((= (rem elevation 0.5) 0)(setq MyColour 3))
          (t (setq MyColour 1))
        (command "chprop" pline "" "c" MyColour "")
  • Thanks 1
;         (t
(vl-load-com)
      (setq index 0)
      (repeat ssl
        (cond
          (t
thank you so much.
 Share
