filter list of ssget method does not apply
Hi,
I have put together a script, that requires the user to first select a line then a polyline. It the looks for the next vertices on the polyline (relative to the intersection point of those two lines). On those vertices are blocks that I want to be selected as pre_blk and post_blk respectively. What I dont understand is the ssget method apparently not applying the filter '((0 . "INSERT")) when called. Therefore I end up with the polyline selected as pre_blk (one of the blocks is correctly assigned to post_blk) when I type (sssetfirst nil pre_blk). I would attach a sample dwg but apparently its not possible here. (thanks to Lee-Mac and dlanorh for the supplied functions and code snippets, credited in the code):
(defun c:selectblocks (/)
  (if (setq ss1 (ssget ":S"))
    (if (setq ss2 (ssget ":S"))
      ;; Look for previous and next vertex on polyline
      (foreach pnt (LM:intersectionsbetweensets ss1 ss2)
        ;; get the next vertices relative to the intersection point
        ;; thanks to dlanorh (https://www.cadtutor.net/forum/topic/68855-vertices-of-polyline-near-a-point/)
        (setq poly (vlax-ename->vla-object (ssname ss2 0)))
        (setq p_param (vlax-curve-getparamatpoint poly pnt))
        (setq pre_vtx (vlax-curve-getpointatparam poly (fix p_param))        ;gets the coords of the vertex before
              post_vtx (vlax-curve-getpointatparam poly (1+ (fix p_param)))  ;the coords of the vertex after
        ;;get blocks at vertices
        (setq filter '((0 . "INSERT")))
        (setq pre_blk (ssget "_X" (list '(-4 . "=,=,=") (cons '10 pre_vtx) filter)))
        (setq post_blk (ssget "_X" (list '(-4 . "=,=,=") (cons '10 post_vtx) filter)))
        ;;if selection fails, try fence selection:
        (if (not pre_blk)
            (setq co_incr (+ 0.18 (car pre_vtx)))   ;;assuming a circle diameter of 0.25 cm
            (setq rest (cdr pre_vtx))
            (setq incr (cons co_incr rest))
            (setq pre_blk (ssget "_F" (list pre_vtx incr) filter))
        (if (not post_blk)
            (setq co_incr (+ 0.18 (car post_vtx)))  ;;assuming a circle diameter of 0.25 cm
            (setq rest (cdr post_vtx))
            (setq post_blk (ssget "_F" (list post_vtx incr) filter))
;; Intersections Between Sets  -  Lee Mac
;; Returns a list of all points of intersection between objects in two selection sets.
;; ss1,ss2 - [sel] Selection sets
(defun LM:intersectionsbetweensets (ss1 ss2 / id1 id2 ob1 ob2 rtn)
  (repeat (setq id1 (sslength ss1))
    (setq ob1 (vlax-ename->vla-object (ssname ss1 (setq id1 (1- id1)))))
    (repeat (setq id2 (sslength ss2))
      (setq ob2 (vlax-ename->vla-object (ssname ss2 (setq id2 (1- id2))))
            rtn (cons (LM:intersections ob1 ob2 acextendnone) rtn)
  (apply 'append (reverse rtn))
;; Intersections  -  Lee Mac
;; Returns a list of all points of intersection between two objects
;; for the given intersection mode.
;; ob1,ob2 - [vla] VLA-Objects
;;     mod - [int] acextendoption enum of intersectwith method
(defun LM:intersections (ob1 ob2 mod / lst rtn)
  (if (and (vlax-method-applicable-p ob1 'intersectwith)
           (vlax-method-applicable-p ob2 'intersectwith)
           (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
    (repeat (/ (length lst) 3)
      (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
            lst (cdddr lst)
  (reverse rtn)
Since your using :S with ssget just switched them over to entsel
opted not to extend either object to get intersections. please change to meat your needs.
(defun c:selectblocks (/ obj1 obj2 pnt poly p_param pre_vtx pre_blk post_vtx post_blk incr)
  (if (and (setq obj1 (car (entsel "\nSelect Line: "))) (setq obj2 (car (entsel "\nSelect Polyline: "))))
    (foreach pnt (LM:intersections (vlax-ename->vla-object obj1) (vlax-ename->vla-object obj2) acextendnone) ;Do not extend either object
      (setq poly (vlax-ename->vla-object obj2)
      (if (not (setq pre_blk (ssget "_X" (list '(0 . "INSERT") (cons 10 pre_vtx)))))
          (setq incr (list (mapcar '+ pre_vtx '(1 0 0)) (mapcar '- pre_vtx '(1 0 0)))) ;extend fence in both directions
          (setq pre_blk (ssget "_F" incr '((0 . "INSERT"))))
      (if (not (setq post_blk (ssget "_X" (list '(0 . "INSERT") (cons 10 post_vtx)))))
          (setq incr (list (mapcar '+ post_vtx '(1 0 0)) (mapcar '- post_vtx '(1 0 0))))  ;extend fence in both directions
          (setq post_blk (ssget "_F" incr '((0 . "INSERT"))))
(defun LM:intersections ( ob1 ob2 mod / lst rtn )
                  lst (cdddr lst)
    (reverse rtn)
Edited by mhupp
  • Agree 1
in this line
1. do not mix " '(( " and " (list (cons ", it's better to know.
you can convert that (setq filter (list (cons 0 "INSERT")))
2. so after convert, you can see that (list (cons 0 "INSERT")) is already in the list.
in example, when you use ssget
(ssget "_X" '((0 . "INSERT"))) is correct.
but your example has
(ssget "_X" (list ~~ '((0 . "INSERT"))))
if you want to add filter option. you can play in that () like this
(ssget "_X" (list (cons 0 ~~) (cons 8 ~~) (cons 10 ~~)))
3. (cons '10 -> (cons 10
Edited by exceed
  • Thanks 1
On 7/9/2022 at 7:40 AM, exceed said:
in this line
Thank you very much @exceed and @mhupp, I wasn't aware of how sensitive the filter option is towards mixing those formats of dotted pair lists. When debugging, the value of what I got in (list '(-4 . "=,=,=") (cons '10 pre_vtx) filter) seemed legitimate, I also expected there to be an error message when the list is malformatted, instead it seems to be ignored. Since @devitg asked, and for further clarification (though it now works as intended), I now attached the dwg. Thank you all!
selectblocks.dwg
For me when in doubt just use cons for everything.
(setq pre_blk (ssget "_X" (list (cons -4  "=,=,=") (cons  10 pre_vtx)(cons 0 "INSERT"))))
Edited by BIGAL
  • Like 2
