Selecting grips
Hey guys,
Sorry to pull a Houdini here. Work's kept me exceedingly busy.
Here's my question:
Is there a way to select multiple grips without picking them one by one?
I have to do alot of editing to erection drawings and life would be ever so much simpler if I could use a crossing bow to pick the grips.
-Crom
witht the shift key you still need to pick each grip one by one...if you're objective is to stretch things then use the cp (crossing polygon) option of the stretch command...the trick here is to only enclose the "grip" portions of the entities in the crossing polygon...it took me a while to get used to it but once you understand how it works...
Guest Alan Cullen
You will have to use things like STRETCH etc......
  • 1 year later...
it used to be but now it's not. autodesk... redefining the definition of "fix" since eighty six.
in 05 you could enter stretch, select the object(s) with the pickbox and left to right window only the grip points you were interested in adjusting. this command was so efficient and is so missed.
