freeze layer vport
au-s
Hi I have this lisp:
(defun GetList ()
 (setq iNest nil
eList nil
 (setq iNest (length (last ePick)))
 (if (= iNest 1)
   (setq eList (entget (car ePick)))
   (setq eList (entget (nth (- iNest 2) (last ePick))))
 (setq sLayer     (cdr (assoc 8 eList))
sObjectType (cdr (assoc 0 eList))
 (if (= "INSERT" sObjectType)
     (setq sObjectType "BLOCK"
    sBlockname (cdr (assoc 2 eList))
(defun C:test ()
 (setq old_cmd (getvar "cmdecho")
old_err *error*
*error* xlist_err
 (setq oldlay (getvar "clayer"))
 (command "_layer" "s" "0" "")
 (setvar "cmdecho" 0)
 (command "_.undo" "_be")
 (prompt "\nChoose a viewport: "
   (if (= (getvar "tilemode") 0)
 (command "_mspace")
 (setq koll 4)
 (while (> koll 3)
   (setq ePick (nentsel "\nChoose a layer to be frozen : "))
   (if (> (length ePick) 3)
(GetList)
(command "_vplayer" "f" slayer "" "")
   (setq koll (length ePick))
 (setq *error* old_err)
 (command "_.undo" "_end")
 (setvar "clayer" oldlay)
 (setvar "cmdecho" old_cmd)
 (command "_pspace")
 (princ)(alert "It only runs in PSPACE"))
It gives me an error in vlide:
; error: too many arguments: (IF (= (GETVAR "tilemode") 0) etc etc etc ....
What I want is for user to:
1. Pick a viewport
2. Choose a layer to freeze from an XFREF
3. When command is done, exit mspace
Thanx
Or maybe you have another nicer one :)
It returns too many arguments I believe because you have missed the use of a progn statement after that IF function, therefore it is trying to evaluate too many terms :thumbsup:
Yes Sir! :)
I noticed ... :) Thanx LeeMac & badien
