Autocad LT 2009 failing to save!
Hi I have relaunched my LT 2009 after some time and have had trouble when recently trying to manually save the file.
I have been working on the drawing for a couple of hours. It did save intially.
Quote
"One or more objects in this drawing cannot be saved to the specified format. the operation was not completed and no file was created."
I have tried saving in all the earlier versions and also in the dxf format.
The drawing is a simple ground floor plan with some hatching for floor finishes.
I have solved the problem thank you.   In case the solution is of use to others I had been saving to the Data drive. The problem was
solved by selecting a folder within Documents on the C drive.
