Delete layer command
organetic
Since you asked :
(defun c:del-layer (/ ent l_name ss cntr amt ssent)
;;; erases all objects on selected layer then purges that layer
 (setvar 'clayer "0") ; set layer to 0
 (if
   ; make sure we get something
   (and (setq l_name (getstring "\nSpecify Layer Name: "))
    (tblsearch "Layer" l_name)) ; test
     ; create a selection set of all entites on layer 'l_name'
     (setq ss (ssget "X" (list (cons 8 l_name)))
           ; set 'cntr' to number of items in selection set
           cntr (1- (sslength ss))
           amt (itoa cntr); make a string from an integer
     (if
       ; does the sel set have anything in it
       (> cntr 0); test
       (while
         ; as long as 'cntr' is greater than or equal to 0
         ; keep looping
         (>= cntr 0)
         ; extract the ename from the sel set
         (setq ssent (ssname ss cntr))
         (entdel ssent); delete that entity
         (setq cntr (1- cntr)); subtract 1 from cntr
 (command "_.purge" "LA" l_name "N")
 (princ (strcat "\nErased " amt " items"))
How is that any different from using Express Tools > Layer Delete and the Type-it option?
I agree. Actually, I would prefer express tools, since LAYDEL will take care of nested objects as well. I don't think the LISP referenced by the OP does that, does it?
I'm almost always one to fall into the trap of creating some huge code that could do the same thing as a one line macro...
Don't knock it. That probably explains why you're so good at it. I guess I'm more the "lazy drafter" type. LOL
