Hi friends
i made a table by lisp and need the last column to be equation in the lisp himself
what i need to do
somthing like "=b3*c3"
count bars .lsp
While I can't say for your specific table, I'd approach this in the following way:
1. Loop through the table, using the rowcount (vla-get-rows table) as an index
2. Access data in hardcoded columns (vla-gettext table row column) with the index representing the row.
3. Iterate the index every iteration.
So you would end up with something like:
(setq size (vla-get-rows table)
	  j 0
(repeat size
	(vla-settext table j 2 (* (read(vla-gettext table j 0)) (read(vla-gettext table j 1))))
	(setq j (+ j 1))
This will likely not work with your table but the process should be about the same.
thx
i try the process but the resault is fixed and not linked to the cell
hi friends
i find a way
the sulotion is
Quote
(vla-settext myTable row 5 "=B3*C3*PI*D3*D3*0.25*E3*7.86*0.001*0.01")
Edited by mousho
Have a look inside getexcel.lsp it has a row column (2 3) =  "B3" defun, by Gile. So could create your string.
