Distance point to polyline
Steven P
 Share
Good afternoon,
Hope this is a quick one, I want to check if a point that a user has selected is on a polyline or not. I am sure this is dead simple and there -should- be a copy and paste solution out there, be grateful if anyone has something they can share..... if not subtle hints are also good and a great way for me to learn a bit more.
The polyine will have been selected with a single click ssget: (setq obj1 (ssget "_:S" '((0 . "LWPOLYLINE"))) )
Thanks
You can use the function vlax-curve-getclosestpointto to check if the distance between the picked point and closest point to object is equal to zero then its on otherwise its not.
  • Like 2
Which System variable hold the point where the user do the SSGET ?
For Entsel is known
(setq point ( cdr (entsel "\n Select an entitytie" )))
Thanks in advance
 Share
