jonathann3891 Posted August 2 Share Posted August 2 I'm working on a lisp that will label an object's layer with a multileader and a field, but I've hit a wall. I cannot get the field to populate. What am I missing? (defun C:TTT (/ ss sss) (and (setq SS (car (entsel "\nSelect item to label: "))) (setq SSS (tblsearch "layer" (cdr (assoc 8 (entget SS))))) (progn (command "_.MLEADER") (while (= (logand (getvar 'cmdactive) 1) 1) (command pause)) ; this is required for multisegment mleader (vla-put-TextString (vlax-ename->vla-object (entlast)) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-ObjectId SS)) ">%).Layer>%") ) (vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) ); progn ); and (princ) ); defun Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 2 Share Posted August 2 You need to convert the entity selected 'ss' to vla-object. (vla-get-ObjectId (vlax-ename->vla-object SS)) Besides that, you don't the tablesearch expression that assigned to variable 'sss' 2 Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted August 2 Author Share Posted August 2 11 minutes ago, Tharwat said: You need to convert the entity selected 'ss' to vla-object. (vla-get-ObjectId (vlax-ename->vla-object SS)) Besides that, you don't the tablesearch expression that assigned to variable 'sss' Thanks @Tharwat! The last issue is this line of code doesn't appear to be working: (vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) The field isn't updating unless I regen or select the multileader. (defun c:ttt (/ ss) (vl-load-com) (setq SS (car (entsel "\nSelect item to label: "))) (progn (command "_.MLEADER") (while (= (logand (getvar 'cmdactive) 1) 1) (command pause)) ; this is required for multisegment mleader (vla-put-TextString (vlax-ename->vla-object (entlast)) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-ObjectId (vlax-ename->vla-object SS))) ">%).Layer>%") );vla (vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) );progn (princ) );defun Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 2 Share Posted August 2 That's due to While function and it does not stop right after the last vertice. It would be much better to use your certain Mleader style then you know the number of vertices required to ask the user to specify in prior of setting the field value to it, otherwise it would be much professional way to get the number of vertices that the current mleader style uses then you modify your codes and use something like repeat ( based on the number of vertices ) then finally set the text string < field > . 1 Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted August 3 Author Share Posted August 3 14 hours ago, Tharwat said: That's due to While function and it does not stop right after the last vertice. It would be much better to use your certain Mleader style then you know the number of vertices required to ask the user to specify in prior of setting the field value to it, otherwise it would be much professional way to get the number of vertices that the current mleader style uses then you modify your codes and use something like repeat ( based on the number of vertices ) then finally set the text string < field > . Unfortunately that's above my skill level Quote Link to comment Share on other sites More sharing options...
mhupp Posted August 3 Share Posted August 3 (edited) This allows you to pick two points. so you don't need the while. (command "_.MLEADER" pause pause) Edited August 3 by mhupp Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted August 3 Author Share Posted August 3 (edited) 33 minutes ago, mhupp said: This allows you to pick two points. so you don't need the while. (command "_.MLEADER" pause pause) I just rewrote the whole thing and made it much simpler and without a field. (defun c:ll (/ ss tStr) (vl-load-com) (setvar 'Cmdecho 0) (setq SS (car (entsel "\nSelect item to label: ")) tStr (cdr (assoc 8 (entget SS))) oLayer (getvar 'clayer) );setq (if (tblsearch "layer" "c_gen_Text") (command "_layer" "s" "c_gen_Text" "c" "50" "" "lt" "continuous" "" "") (command "_layer" "m" "c_gen_Text" "c" "50" "" "lt" "continuous" "" "") );if (vl-cmdf "_.mleader" pause pause tStr) (setvar 'clayer olayer) (setvar 'Cmdecho 1) (princ) ) Edited August 3 by jonathann3891 1 Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted August 3 Author Share Posted August 3 Currently it will end if nothing is selected. How do I go about looping until anything is selected? Quote Link to comment Share on other sites More sharing options...
mhupp Posted August 3 Share Posted August 3 (edited) this will loop until you don't select anything. (defun c:ll (/ ent str) (setvar 'cmdecho 0) (setq oLayer (getvar 'clayer)) (if (tblsearch "layer" "c_gen_Text") (setvar 'clayer "c_gen_Text") ;make layer current (command "_layer" "m" "c_gen_Text" "c" "50" "" "lt" "continuous" "" "") ) ;if (while (setq ent (car (entsel "\nSelect Entity: "))) (setq str (cdr (assoc 8 (entget ent)))) (vl-cmdf "_.mleader" pause pause str) ) (setvar 'clayer olayer) (setvar 'cmdecho 1) (princ) ) --edit this one uses the point of entsel in mleader so you have one less click (defun c:ll (/ ent str) (setvar 'cmdecho 0) (setq oLayer (getvar 'clayer)) (if (tblsearch "layer" "c_gen_Text") (setvar 'clayer "c_gen_Text") ;make layer current (command "_layer" "m" "c_gen_Text" "c" "50" "" "lt" "continuous" "" "") ) ;if (while (setq ent (entsel "\nSelect Entity: ")) (setq pt (cdr ent)) (setq str (cdr (assoc 8 (entget (car ent))))) (vl-cmdf "_.mleader" pt pause str) ) (setvar 'clayer olayer) (setvar 'cmdecho 1) (princ) ) Edited August 3 by mhupp Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted August 3 Author Share Posted August 3 Thank you @mhupp! 1 Quote Link to comment Share on other sites More sharing options...
