Guest Posted September 23, 2022 Posted September 23, 2022 I am trying to do some changes ton an old dimension lisp code. Tis code select a polyline and insert dimension text detween vertex of polyline (open/ close) I want to add option menu for layer and font style. The problem is that when i choose option 1 use the font style for the option 1 but insert the text in option 2 layer. I dont know why. Can any one help me? (Defun C:TEST1 (/ txtstl txtsze stryn prfx sufx svr scl ht pt pti ptx pty old oldpl nodpl ptyp pllst i n prin meta distmeta ptdist angprin angmeta angtxt ptp alfa nlin xlin ylin dlin flg xreg yreg na xa ya) ;*************drawing set-up*************************** (command "undo" "m") (setvar "unitmode" 0) (setvar "aunits" 2) (setvar "angbase" (/ pi 2)) (setvar "angdir" 1) (setvar "auprec" 4) (setvar "lunits" 2) (setvar "luprec" 3) (setvar "dimzin" 0) (setq svr(getvar "osmode")) (setq txtstl(getvar "textstyle")) (setq txtsze(getvar "textsize")) (setvar "cmdecho" 0) (setq flg 1) (setvar "cmdecho" 0) (setq scl (getvar "useri1")) ; dont change this (setq ht(* 0.00175 scl)) ; dont change this ;------------------------------------------------------------ (TEXTPAGE) (princ "\n")(princ "\n")(princ "\n") (progn (initget "1 2") (setq l (cond ((getkword "\n select: 1. option1. 2. option2. " ) ) ("1") ) ) (if (eq l "1") (command "-style" "diast" "wgsimpl.shx" "0" "1.2" "0" "N" "N" "N") (command "_layer" "_m" "dim" "_c" "93" "" "_lw" "0.30" "" "") ) (if (eq l "2") (command "-style" "ktdiast" "wgsimpl.shx" "0" "1" "0" "N" "N" "N") (command "_layer" "_m" "KT-DIM" "_c" "191" "" "_lw" "0.30" "" "") ) ) ;-------------------------------------------------------------------------------------------- :********BOUNDARY LINE********** (setvar "osmode" 0) (setq old(entsel "\n select lwpolyline: ")) (setq oldpl(entget(car old))) (setq nodpl(cdr(assoc 90 oldpl))) (setq ptyp (cdr(assoc 70 oldpl))) (command "area" "e" old) (setq pllst '()) (setq i 0) (setq n 0) (while (car(nth i oldpl)) (if (= (car(nth i oldpl)) 10) (progn (setq pllst (append pllst (list (cdr(nth i oldpl))))) (setq n(+ 1 n)) );endprogn );endif (setq i (+ i 1)) );endwhile (if (= ptyp 1) (progn (setq pllst (append pllst (list(nth 0 pllst)))) (setq pllst (cdr pllst)) );endprogn );endif ; (main) ;);close defun ;(defun main() ;******* (setq alfa 193) (foreach n pllst (command n)) (command "") (command "erase" pt "") (setq i 0 prin 0 meta 0) (while (car(nth i pllst)) (setq prin (- i 1)) (setq meta (+ i 1)) (if (= i 0) (setq prin (- n 1)) ) (if (= i (- n 1)) (setq meta 0) ) (setq angprin (angle (nth i pllst) (nth prin pllst))) (setq angmeta (angle (nth i pllst) (nth meta pllst))) (setq distmeta (distance (nth i pllst) (nth meta pllst))) ;------------------------------------------------------------------------------- (setq ptdist (polar (polar (nth i pllst) angmeta (/ distmeta 2)) (+ angmeta (* (/ pi 2) flg)) (* 0.5 ht))) (setq angtxt(- 500 (/ (* 400 angmeta) (* 2 pi)))) (if (> angtxt 400) (setq angtxt (- angtxt 400)) ) (if (> angtxt 200) (progn (setq ptdist (polar (polar (nth i pllst) angmeta (/ distmeta 2)) (+ angmeta (* (/ pi 2) flg)) (* 1.50 ht))) (setq angtxt (- angtxt 200)) );endprogn ) (command "text" "j" "c" ptdist ht angtxt (rtos distmeta 2 2) ) (setq i (+ i 1)) );endwhile (if (= ptyp 0) (command "erase" "l" "") ) (setvar "osmode" svr) (setvar "cmdecho" 1) (setvar "textstyle" txtstl) (setvar "textsize" txtsze) ; layer 0 (mapcar 'setvar '("clayer" "cecolor" "celtype" "celweight") (list "0" "BYLAYER" "BYLAYER" -1)) (princ) );close defun Thanks Quote
mhupp Posted September 23, 2022 Posted September 23, 2022 (edited) The if statements after picking the options will only run the first line if true or 2nd line if false. if you want to run multiple lines of code after an if statement you have to use (progn (if statement (progn (line 1) (line 2) ... ) ;end progn );end if when you pick option 1 (command "-style" "diast" "wgsimpl.shx" "0" "1.2" "0" "N" "N" "N") ;true (command "_layer" "_m" "KT-DIM" "_c" "191" "" "_lw" "0.30" "" "") ;false when you pick option 2 (command "_layer" "_m" "dim" "_c" "93" "" "_lw" "0.30" "" "") ;false (command "-style" "ktdiast" "wgsimpl.shx" "0" "1" "0" "N" "N" "N") ;true This uses cond after the option they don't need progn to run multiple lines of code. also they stop and don't check the other conditional statements if one is found to be true. also uses visual lisp to calculate the text. (Defun C:TEST1 (/ txtstl txtsze stryn prfx sufx svr scl ht pt pti ptx pty old oldpl nodpl ptyp pllst i n prin meta distmeta ptdist angprin angmeta angtxt ptp alfa nlin xlin ylin dlin flg xreg yreg na xa ya ) ;*************drawing set-up*************************** (command "undo" "m") (setvar 'unitmode 0) (setvar 'aunits 2) (setvar 'angbase (/ pi 2)) (setvar 'angdir 1) (setvar 'auprec 4) (setvar 'lunits 2) (setvar 'luprec 3) (setvar 'dimzin 0) (setq svr (getvar "osmode")) (setq txtstl (getvar "textstyle")) (setq txtsze (getvar "textsize")) (setvar "cmdecho" 0) (setq flg 1) (setvar "cmdecho" 0) (setq scl (getvar "useri1")) ; dont change this (setq ht (* 0.00175 scl)) ; dont change this ;------------------------------------------------------------ (TEXTPAGE) (princ "\n\n\n") ;(princ "\n") (princ "\n") (princ "\n") (initget "1 2") (setq opt (cond ((getkword "\n Select: Option[1] or Option2: ")) ("1") ) ) (cond ((= opt "1") ;will run both lines of code (command "-style" "diast" "wgsimpl.shx" "0" "1.2" "0" "N" "N" "N") (command "_layer" "_m" "dim" "_c" "93" "" "_lw" "0.30" "" "") ) ((= opt "2") ;will run both lines of code (command "-style" "ktdiast" "wgsimpl.shx" "0" "1" "0" "N" "N" "N") (command "_layer" "_m" "KT-DIM" "_c" "191" "" "_lw" "0.30" "" "") ) ) (setvar 'osmode 0) (setq poly (vlax-invoke (vlax-ename->vla-object (car (entsel "\nSelect lwpolyline:"))) 'explode)) ;makes a copy of the polyline and explodes it (foreach obj poly ;processes each entity in poly list ;adding all sub entitys into a list named poly (cond ((eq (vla-get-Objectname obj) "AcDbArc") (setq len (vla-get-arclength obj)) (setq p1 (vlax-get obj 'StartPoint)) (setq p2 (vlax-curve-getPointAtDist obj (/ len 2))) (setq p3 (vlax-get obj 'EndPoint)) (setq ang (angle p1 p3)) (entmakex (list (cons 0 "TEXT") (cons 10 p2) (cons 11 p2) (cons 40 txtsze) (cons 50 ang) '(71 . 0) '(72 . 1) '(73 . 2) (cons 1 (rtos len 2 2)) ) ) (vla-delete obj) ) ((eq (vla-get-Objectname obj) "AcDbLine") (setq len (vla-get-length obj)) (setq p1 (vlax-get obj 'StartPoint)) (setq p2 (vlax-curve-getPointAtDist obj (/ len 2))) (setq p3 (vlax-get obj 'EndPoint)) (setq ang (angle p1 p3)) (entmakex (list (cons 0 "TEXT") (cons 10 p2) (cons 11 p2) (cons 40 txtsze) (cons 50 ang) '(71 . 0) '(72 . 1) '(73 . 2) (cons 1 (rtos len 2 2)) ) ) (vla-delete obj) ) ) ) (setvar "osmode" svr) (setvar "cmdecho" 1) (setvar "textstyle" txtstl) (setvar "textsize" txtsze) (setvar "textstyle" txtstl) (mapcar 'setvar '( "clayer" "cecolor" "celtype" "celweight") (list "0" "BYLAYER" "BYLAYER" -1)) (princ) ) Edited September 23, 2022 by mhupp Quote
Guest Posted September 23, 2022 Posted September 23, 2022 Hi mhupp. Thanks for the replay.I try your code but is not run both lines of code. Create the text styles but use as text style the STANDARD. Any ideas? Quote
mhupp Posted September 23, 2022 Posted September 23, 2022 it errors for me when wgsimpl.shx is called. since i don't have that font I commented it out when i was checking my code. make sure that font is loaded? Quote
