sarah Posted February 18, 2009 Posted February 18, 2009 Hi all, I currently use autocad lt 2008 with a 3d bolt-on called toolbox lt. I am self-taught so apologies if my methods may seem a bit unconventional to you guys. I am trying to show this object with a face on the top of it so when i show it using HIDE and in place you can't see the structure inside of the object. Normally I am ok with this, but because this polygon shape is awkward and involves arcs as well as straight lines i'm not sure how to go about it. If anyone could help i would be very grateful Thankyou in advance Sarah traverse wall cap.dwg Quote
SEANT Posted February 18, 2009 Posted February 18, 2009 That group (with thickness) could be capped with a region created from a copy of the group. It should work for a Hide operation. traverse wall cap -w-cap.dwg Quote
sarah Posted February 18, 2009 Author Posted February 18, 2009 thankyou so much...thats brilliant. that never occured to me. cheers sarah Quote
