au-s Posted February 18, 2009 Share Posted February 18, 2009 Hello, I do not know exactly how to do this. Anyways if I want a lispcommand "test" (defun c:test () to be executed I type test. If I type test but then hit ESC I want lisp not to do anything. The escape is (command) ?? Here is an example: (defun C:test (/ cDim oldlay) (setq oldlay (getvar "clayer")) (vl-load-com) (if (not (tblsearch "LAYER" "A-------D2-------A")) (command "-layer" "M" "A-------D2-------A" "C" "cyan" "A-------D2-------A" "") (setvar "clayer" "A-------D2-------A") ) ; end if (load "K:\\CAD\\Dimvariables.lsp") (Dim_Variabler) (LinjerDim) (setvar "dimscale" 1) (setq p1 (getpoint "\nFirst point: ")) (setq p2 (getpoint p1 "\nSecond point: ")) (setq p3 (getpoint p2 "\nPosition: ")) (princ) (and(vl-cmdf "_.dimlinear" p1 p2 p3) (setq cDim(vlax-ename->vla-object(entlast))) (vla-get-Measurement cDim)) (DESCRIBE) (setvar "clayer" oldlay))(command)) (princ) ); end So here I want if I type test the dimension starts. And layer creation starts. Allthough after typing the command I choose to hit ESC I want the lisp to completely exit and undoing what its had done... Can it be done like: (if (test) (progn ...here comes all the code (undo "BE") );end Quote Link to comment Share on other sites More sharing options...
uddfl Posted February 18, 2009 Share Posted February 18, 2009 You would need to add an error trapping function. http://www.afralisp.net/lispa/lisp6.htm Quote Link to comment Share on other sites More sharing options...
