Is possible apply transformd method to a rectangular array of blocks
lewis770227
I´m doing a code that created an array of blockRefObject and After that this resulting array I would like to modificate by transform method.
Best regards
Look this code:
Sub Example_ArrayRectangular()
' Create the circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
Dim newUCS As AcadUCS
Dim currUCS As AcadUCS
Dim varUCSMatrix As Variant
pb = ThisDrawing.Utility.GetPoint(, "basepoint: ")
px = ThisDrawing.Utility.GetPoint(, "xdirection: ")
py = ThisDrawing.Utility.GetPoint(, "ydirection: ")
center(0) = 2#: center(1) = 2#: center(2) = 0#
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
ThisDrawing.Application.ZoomAll
' Define the rectangular array
Dim numberOfRows As Long
Dim numberOfColumns As Long
Dim numberOfLevels As Long
Dim distanceBwtnRows As Double
Dim distanceBwtnColumns As Double
Dim distanceBwtnLevels As Double
numberOfRows = 5
numberOfColumns = 5
numberOfLevels = 1
distanceBwtnRows = 1
distanceBwtnColumns = 1
distanceBwtnLevels = 1
Set newUCS = ThisDrawing.UserCoordinateSystems.Add(pb, px, py, "TestUCS")
varUCSMatrix = newUCS.GetUCSMatrix
' Create the array of objects
Dim retObj As Variant
retObj = circleObj.ArrayRectangular(numberOfRows, numberOfColumns, numberOfLevels, distanceBwtnRows, distanceBwtnColumns, distanceBwtnLevels)
retObj.TransformBy varUCSMatrix
ZoomAll
End Sub
An error ocurrs in line transformBy, beside I don´t know how work distanceBwtnLevels and numberOfLevels in array definition
The .TransformedBy method is limited to individual entities. You’ll probably have to do something like this:
Dim retObj() As AcadEntity
Dim varEnt As Variant
Dim ent As AcadEntity
For Each varEnt In retObj
  Set ent = varEnt
  ent.TransformBy varUCSMatrix
Next
circleObj.TransformBy varUCSMatrix
You may also find that ThisDrawing.UserCoordinateSystems.Add is pretty finicky about the input coordinates. Additional steps may be required to ensure that the two vectors are perpendicular.
