Is there a version of impression for LT or is the another program that has the same functionality, just for Autocad Lt?
Thanks,
scott
Per AutoDesk:
"Autodesk Impression is available to AutoCAD® software products’ subscription customers."
ya but i thought you could only use if you had the full version of autocad
Impression has nothing to do with 3D. It should work fine for LT. In fact, you should have an Impression toolbar available to you. Go into your CUI and look around. It should be there.
Impression is a stand alone application. In fact I agree that Impression would be good for LT. It can open either a dwg or dwf file so LT users would have no issue bringing in their CAD work.
i found it in my CUI. downloaded the trail version, it's really great! There is also another great program I just found out about it's called M-Color, it's also really cool!!
thanks again:D
