missing parentheses?
chelsea1307
i have a folder of lisps that is supposed to load upon opening a dwg. It stops loading them and gets stuck wanting me to select object to scale. Can someone take a look at this and tell me where the problem lies and how to fix it. Im assuming its lisp because if i dont have them load upon opening i dont have the problem
this is what my command line says
Opening an AutoCAD 2004/LT 2004 format file.
Resolve Xref "0814 TIT": C:\Documents and Settings\Monty\Desktop\Jobs\2008-086
Living Learning Center\Dwgs\0814 TIT.dwg
"0814 TIT" loaded: U:\2008-086 UNR - New Dorm (RE)\Dwgs\0814 TIT.dwg
"0814 TIT" reference file may have changed since host drawing was last saved.
Resolve Xref "28086 Backgrnd": C:\Documents and
Settings\Monty\Desktop\Jobs\2008-086 Living Learning Center\Dwgs\28086
Backgrnd.dwg
"28086 Backgrnd" loaded: U:\2008-086 UNR - New Dorm (RE)\Dwgs\28086 Backgrnd.dwg
"28086 Backgrnd" reference file may have changed since host drawing was last
saved.
Regenerating layout.
Press ENTER to continue:
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
; error: LOAD failed: "c:/acadsupport/LSP/DRAFT"
AutoCAD menu utilities loaded.; error: syntax error
c:CHText loaded. Start command with CHT.; error: no function definition:
OK_BUTTON
DDTXT Loaded, type DDTXT to start
DLINE loaded.
FLEX LOADED
C:XPlode loaded. Start command with XP or XPLODE.; error: An error has
occurred inside the *error* functiontoo many arguments
; error: An error has occurred inside the *error* functiontoo many arguments
DOSLib AutoCAD R14
PREP v3.2 loaded. DOSLib AutoCAD R14
PREP v3.2 loaded. Copyright © 1999 by Bud Siebold. DOSLib AutoCAD R14
PREP v3.2 loaded. Copyright ©2000 by Bud Siebold.
Type AboutPrep for more information.
Pick entities you want to scale:
Select objects: *Cancel*
Select objects:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command: *Cancel*
Available command: SMASHP (Smash Polylines)
Command: Loaded 'tcloud' type 'TCLOUD' to execute.; error: An error has
*Cancel*
