Need a LISP to modify XXX characters and increment them
shailujp
@Steven P@mhupp
I got done several drawings quickly using the code. Saved a lot of time. Thank you!
I came across a drawing which had 311 series. So I changed the code to replace 202 to 311 all places.
Now I am wondering if we can get the prefix input from user first that will determine what series it is (say 202, 311 or any 3 digit number), and then we take the second input "Specify starting number"
Since the first input is required only first time on the drawing, when the next time I start the command in the same drawing, it automatically knows what the first prefix is.
Is that possible? This will make this code super smart I think.
If not, I am happy as is too.
So it was something like  50-CHWS-311XXX-C1A instead of 202 ?
Kinda planed for that so now the variable replace uses getstring to search for what you want to replace with the incremental numbering.
Example
INCATT3
Starting Number: 15
Text to Replace: XXX
50-CHWS-311XXX-C1A would change to 50-CHWS-311015-C1A
*only replaces the first XXX it comes across
50-CXXX-311XXX-C1A would change to 50-C015-311XXX-C1A
(defun c:INCATT3 ( / num tag pre ss1 )
  (vl-load-com)
  (if (and
        (setq i (getint "\nStarting Number: "))
        (setq replace (getstring "\nText to Replace: "))
        (setq l (1+ (strlen replace)))
      (setq num (AT:NumFix (itoa i) (strlen replace)))  ;convert inter to sring before selection
      (while (setq ss (ssget "_+.:E:S:L" '((0 . "INSERT") (66 . 1))))
        (if (and (setq tagstring (getpropertyvalue (ssname ss 0) "LINE")) (setq n (vl-string-search replace tagstring))) ;if block has ATTRIBUTE line and contains
          (progn        ;the string "202XXX" update to new string
            (setpropertyvalue (ssname ss 0) "LINE" (strcat (substr tagstring 1 n) num (substr tagstring (+ n l))))
            (setq i (1+ i))
          (princ (strcat "\"LINE\" Attribute not found or doesn't contain \"" replace "\""))
(defun AT:NumFix (s n)
 ;; Fix number string with leading zeros
 ;; s - Number string to fix
 ;; n - Number of characters for final string
 ;; Alan J. Thompson, 10.29.09
 ;; (AT:NumFix i 3) i= 1 = 001
  (if (< (strlen s) n)
    (AT:NumFix (strcat "0" s) n)
    s
Edited by mhupp
updated code
Example
INCATT3
Starting Number: 15
  (vl-load-com)
  (if (and
      (setq num (AT:NumFix (itoa i) 3)) ;convert inter to sring before selection
            (setq i (1+ i))
    s
That worked wonderfully.
I came across only one drawing (seemed like an exception though) which has only one X (eg. 200-DD-11021200X-C1A). So I copied the code and changed all "3" to "1" and "001" to "1". It worked for that case as well.
(defun c:INCATTM2 ( / num tag pre ss1 )
  (vl-load-com)
  (if (and
      (setq num (AT:NumFix (itoa i) 1)) ;convert inter to sring before selection
            (setq i (1+ i))
 ;; (AT:NumFix i 1) i= 1 = 1
    s
I guess I can copy and create for 2 digit as well similarly if needed.
I want to check one last thing. Can this code ask for same length input (say two XX) and replace same length output (01) and so on?
X      1
XX   01
XXX 001
XXXX 0001
Edited by shailujp
X      1
XX   01
XXX 001
XXXX 0001
updadte  this line of code in both places.
Edited by mhupp
mhupp, you are AWESOME! That worked perfectly well. Thank you so much for your help on this. Much appreciated!
  • 2 weeks later...
hello,
About the last comment..       (updadte  this line of code in both places.)
Where can I update?
Edited by cadmaster1004
1 hour ago, cadmaster1004 said:
hello,
Where can I update?
last code I posted is updated.
