why is this not working
tonyvent
the following lisp is ending at the first * i try to enter. the command is asking for that to be entered and it just doesnt happen for some reason.
(defun c:cfade ( / filename)
  (command "-layer" "xref" "c" "*" "tr" "*" "" "" "")
  (command "-layer" "t" "*" "on" "*" "" "")
  (while (setq filename (getfiled "Select Excel File:" (getvar 'dwgprefix) "xlsx" 2))
    (LayersFromFile filename "Transparency")
    (LayersFromFile filename "Color"))
nope it doesn't work at my computer too... if I type xref it only seems to want to reset the xref layers. maybe a bug in autocad? if I want to change the color for example I have to use something like -layer color 001|* red or something. Hope somebody else has a solution for this...
Edited by rlx
44 minutes ago, Lee Mac said:
Try issuing (initcommandversion) prior to the first command call.
tried that but wasn't working but now I see what i did wrong , tried to give a argument :facepalm:
