I want to make a section of a model I made in 3dsMax.
I opened it in AutoCAD as a 3ds file & as a DWG file, but i didn't succeed to make a section with SLICE tool or with SECTION PLANE tool.
I'm not familiar with AutoCAD, but i must have my model in AutoCAD, so Maybe someone can guide me. or - maybe it's not possible because the model is from max....?
Thanx
You will need a solid. Can you zip and attach the dwg here?
Maybe it is not the best solution but try this:
1.Explode the model
2.type CONVTOSURFACE -it will convert the 3d faces to surfaces
3.type THICKEN -add a desired value and your model will become a bunch of 3d solids(wich i can't seem to union together)
p.s. I think this operations are available in autocad 2007?
