3dwannab Posted December 14, 2022 Posted December 14, 2022 I've simply closed ACAD and installed the VBA Module for any of my previous installed but for 2023 it doesn't pick it up. I've done this: Closed ACAD I've downloaded the 2023 module and installed it from https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/download-the-microsoft-vba-module-for-autocad.html Opened ACAD again and ran the command _vbaide. But it's showing me this below. What gives? Quote
3dwannab Posted December 15, 2022 Author Posted December 15, 2022 Thanks, but this only brings up this. Quote
BIGAL Posted December 15, 2022 Posted December 15, 2022 It is showing not installed, sorry no 2023 so can not test, sounds like an Admin setting issue when installing. Some downloads you need to go to properties and down bottom click unlock. In c:/Program files/Autodesk there should be a directory called "AutoCAD 2023 VBA Enabler" if installed check to see if its there. Quote
3dwannab Posted December 16, 2022 Author Posted December 16, 2022 This is the first installer I remember which never asked me to choose the location. It says it's successfully installed but I've using everything to search for folders or files containing VBA Enabler but no searchy. Just finds the .exe on the desktop. I've tried to right-click on the exe and run as admin but that didn't work either. Quote
BIGAL Posted December 17, 2022 Posted December 17, 2022 Apart from click "Advanced" button in properties and unblock no idea, the other thing is your virus detect maybe stopping it. Contact Autodesk and see what they say. Seems another problem 2023. Interesting when did Autodesk announce VBA would not be supported ? Like 2017 maybe now have 2023. Quote
3dwannab Posted January 4, 2023 Author Posted January 4, 2023 Thanks @BIGAL. I will contact AD and see what is the issue. Quote
