Custom array ?
chavlji
Hello
Does anyone has lisp procedure for array where i should only select
1. number of itterations
2. start point
3. end point
And it would distribute selected items from start point to end point with n/distance spacing.
Autocad's default array only accepts number of itterations and spacing between them...
Following example SHOULD work, but has some strange error...
If I select some random point (that is not OSNAPed) it works superb.
But try select second point as INTERSECTION point of some 3rd line and OTRACK line, it does not work right. Every items are placed correct except last one. This one is always placed on the midpoint of the line!!!
Why it that so?
Please it is driving me crazy...
; Jan Spacing Tool
(prompt "\n ca: Jan Spacing tool")
(defun c:ST ()
 (setvar "cmdecho" 0)
 (setq OBJ (ssget))
 (if (or (= N nil) (< N 2)) (setq N 2))
 (setq N (getint "\nItterations <2>:"))
 (setq T1 (getpoint "\nStart point "))
 (setq T2 (getpoint "\nEnd point\n"))
 (setq X (car T1))
 (setq Y (cadr T1))
 (setq X2 (car T2))
 (setq Y2 (cadr T2))
 ;(PRINC (- Y2 Y))
 ;(foreach msg (list "\n" X "," Y "") (princ msg))
 ;(foreach msg (list "\n" X2 "," Y2 "") (princ msg))
 (initget 1 "Div Mult")
 (setq Tip (getkword "\nDistance < Div, Mult > "))
 (initget 1 "Middle Border")
 (setq Center (getkword "\nEnd point is < Middle, Border > "))
 ;(PRINC (- Y2 Y))
 (if (= Center "Border")
   (setq TBorder (getpoint "\nIzberi robno tocko "))
   (setq X2 (- X2 (- (car TBorder) X) ) )
   (setq Y2 (- Y2 (- (cadr TBorder) Y) ) )
 (PRINC (- Y2 Y))
 (if (= Tip "Div")
   (setq DX (/ (- X2 X) (- N 1) ) )
       (setq DY (/ (- Y2 Y) (- N 1) ) )
       (setq DX (- X2 X) )
       (setq DY (- Y2 Y) )
 (command "_CopyBase" T1 OBJ "")
 (setq i 1)
 (while (< i N)
       (setq TI (list (+ X (* DX i)) (+ Y (* DY i)) ) )
   (command "_PasteClip" TI)
       (PRINC (cadr TI))
       (setq i (+ i 1))
 (foreach msg (list "\nItterated " (- N 1 ) "x on distance DX=" DX ", DY=" DY) (princ msg))
Then the only other thing I would advise is that you save the previous osmode setting before changing it to 0 and restore it when the program is terminated.
Something like this:
(setq olderr *error* *error errtrap)
(defun errtrap    (msg)
 (if oldvars (mapcar 'setvar vlst oldvars))
 (setq *error* olderr)
 (princ))
(setq vlst    (list "CMDECHO" "CLAYER" "OSMODE" "DIMSCALE") ; list altered variables here.
     oldvars (mapcar 'getvar vlst))
