jabastin Posted February 19, 2009 Posted February 19, 2009 Dear all when i explode the dimension its get dispatch. Is there any way to make again a group .... HELP ME Quote
JBullseye74 Posted February 19, 2009 Posted February 19, 2009 Tip: Don't explode the dimensions Once they are exploded there is no way to regroup all the pieces back together again. Just redo the dimension. Quote
hoss Posted February 19, 2009 Posted February 19, 2009 Can you explain why did you explode the dimension anyway? Quote
Ollie8974 Posted April 10, 2009 Posted April 10, 2009 If You want to change the arrow head style, line weight, color, text style ect. make the changes in the propertys box. Quote
CADMASTER1128 Posted April 12, 2009 Posted April 12, 2009 Dear all when i explode the dimension its get dispatch. Is there any way to make again a group .... HELP ME If you want to get the Dim back together, make a Block.. Steps to make a block: 1. Type B 2. Call the block what you want 3. Click "Select Object" 4. Click OK Enjoy the block!! :!::!:Keep in mind that it wont have the properties that it normally has... Quote
