samifox Posted February 1, 2023 Posted February 1, 2023 hi wblock command in Civil has additional prompts, the vanila autocad doesn't. Is there a system variable to suppress those additional prompts, so the command would behave exactly as in vanila AutoCAD? Thanks Shay Quote
TRogers Posted February 1, 2023 Posted February 1, 2023 WBLOCK in Civil 3D is the AutoCAD WBLOCK. There is nothing different. What are you seeing? Quote
samifox Posted February 1, 2023 Author Posted February 1, 2023 (edited) maybe i got confused with MAP Edited February 1, 2023 by samifox Quote
mhupp Posted February 1, 2023 Posted February 1, 2023 If you use wblock and select attributes it will prompt you to define them. You could also setvar EXPERT to 5 that might help Quote
BIGAL Posted February 1, 2023 Posted February 1, 2023 CIV3D wblock do you want to "save Map data" when ran. (command "-wblock" "d:\\acadtemp\\wow.dwg" "" "0,0" ss "" "N") ; civ3d version (command "-wblock" "d:\\acadtemp\\wow.dwg" "" "0,0" ss2 "") ; Acad version Quote
