I have survey dwgs, probably originating in a program other than Autocad, that have a node attached, probably an action node of some sort, or a node for inserting intelligence.
The node is static, i.e. does not change size when zooming, cannot be picked, and is a small solid circle with about 12 lines radiating out to a larger circle.
Is there a way to delete these nodes? from my drawings?
It would help to see the drawing. But being a new member you will not be allowed to attatch. Once you get up to certain # posts you are allowed to attach.
Can you edit the block and then select the node?
Dave
"Most of what I know came from the "F1" key"
The node doesn't seem to be attached to a block. I don't have any blocks in some of the drawings, and the node is still there.
