ColinPearson Posted February 21, 2023 Share Posted February 21, 2023 So this keeps coming up and I feel like it's simple but I just can't wrap my head around it. Attached is a block I'm building up. I'm working on all my movement Actions like Stretch and Rotate, then I've got some other work with a Double Lookup to simulate a multi-Viz Parameter (thanks Libbya from the Autodesk forums!) My problem is with the right top side Rotate. I want to limit the movement of the object in the selection set from 90° - 135° (assuming 0° is to the right and + is CCW). It works fine as-is, and also work fine if I stretch the block longer. However, if I drag the Stretch Grip to the left, then when I try to use the Rotate Grip on the top/right object, the range of travel is flipped or mirrored somehow. Any thoughts would be GREATLY appreciated, this has been making me crazy. test.dwg Quote Link to comment Share on other sites More sharing options...
