Help - Change Linetype and Linetype Scale
barristann
Hi all. Is possible to use lisp to change ALL polylines of layer named "Object_1" and "Object_2" to have
Linetype = Dashed
Linetype Scale = 1.2
Global Width = 1
Thank you
Yes,
Basic ideas:
This link will explains what you need to do to do the selection part:
http://lee-mac.com/ssget.html
and the second or 3rd result of an internet search even does that for you:
https://www.cadtutor.net/forum/topic/71231-select-all-polylines-of-certain-layer-and-fillet-them/
(setq sel (ssget "_X" (list '(0 . "LWPOLYLINE") '(8 . "OBJ1") (cons 410 (getvar 'CTAB)))))
and then the next part use
(command "chprop" sel ... )and follow the prompts you'd use to change the linetype from the selection
