Radu Iordache Posted March 5, 2023 Share Posted March 5, 2023 I would greatly appreciate help on creating a lisp that would do the following: 1. call the bpoly command probably (command "-bpoly") 2. wait for me to make all necessary clicks and create needed polylines till I exit the command probably this should work (found on another thread) (while (= 1 (getvar "cmdactive")) (command pause)) 3. add polylines created on step 2 to a new selection set here I have no idea Note that I also have other polylines in the drawing but I need in the selection set only the ones that were created on step 2 above. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 5, 2023 Share Posted March 5, 2023 it's Sunday night here, need a little patience - see your other thread for an idea (https://www.cadtutor.net/forum/topic/77052-help-needed-to-modify-lisp-for-inserting-area-text-inside-polylines/) Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 5, 2023 Share Posted March 5, 2023 see ssadd for adding polylines to a selection set Quote Link to comment Share on other sites More sharing options...
Radu Iordache Posted March 5, 2023 Author Share Posted March 5, 2023 (edited) @Steven P Thanks for the reply, I made this new topic because I think it summarizes better what the need is. Basically, what I miss is creating the selection set with the new polylines, the rest of the lisp that writes the areas will remain the same. I will check the idea in the older thread and then I will delete it. Edited March 5, 2023 by Radu Iordache Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted March 5, 2023 Share Posted March 5, 2023 (setq el (entlast)) (setq ss (ssadd)) ... DO PICKING WITH BPOLY ... FINISHED... (exit while loop) (while (setq el (entnext el)) (ssadd el ss) ) (sssetfirst nil ss) ;;; your selection set with newly created polylines/regions highlighted... 1 Quote Link to comment Share on other sites More sharing options...
Radu Iordache Posted March 6, 2023 Author Share Posted March 6, 2023 20 hours ago, marko_ribar said: (setq el (entlast)) (setq ss (ssadd)) ... DO PICKING WITH BPOLY ... FINISHED... (exit while loop) (while (setq el (entnext el)) (ssadd el ss) ) (sssetfirst nil ss) ;;; your selection set with newly created polylines/regions highlighted... Worked like magic! Thank you very much! Quote Link to comment Share on other sites More sharing options...
dan20047 Posted March 6, 2023 Share Posted March 6, 2023 watch for when the (entlast) entity is a polyline or block with attributes then entnext selects the subentity. This utility avoids that problem ;;; posted by roy_043 ;;; http://www.theswamp.org/index.php?topic=35626.msg408522#msg408522 (defun kg:GetLast ( / ent newEnt) (setq ent (entlast)) (while (setq newEnt (entnext ent)) (setq ent newEnt) ) ent ) Quote Link to comment Share on other sites More sharing options...
