hi everyone,
i try to print dimstyle for currently open at the command line.its getting error.
kinldy solve anyone.
thanks advance
(defun c:19 ()
  (vl-load-com)
  (setq adoc (vla-get-activedocument(vlax-get-acad-object)))
  (setq tx_style (vla-get-DimStyles adoc))
  (setq tx_style_list '())
  (vlax-for item tx_style
    (setq dwg_style_list (vlax-get-property item 'DimStyles ))
     (setq tx_style_list (append (list dwg_style_list )tx_style_list))
(princ tx_style_list)
Will this do the same?
Quote
(defun tablesearch ( s / d r) ;;List Dimstyles
  (while (setq d (tblnext s (null d)))
    (setq r (cons (cdr (assoc 2 d)) r))
(princ (tableSearch "dimstyle"))
(adding to this, it helps if you tell us what error it is showing by the way, don't always have CAD running to tell me you see)
hi,
thanks for your reply.it works .i want to know if my code only getting error messages at the command line.
4 hours ago, reda said:
hi,
what is the error message by the way?
your problem is on this line I think:
Edited by Steven P
Had 10 minutes to think about this one,
Commented out the line that is causing you a problem and putting in an alternative above it
(defun c:19 ()
  (vl-load-com)
    (setq dwg_style_list (vla-get-Name item) )
;    (setq dwg_style_list (vlax-get-property item 'DimStyles ))
