nainuad Posted February 20, 2009 Share Posted February 20, 2009 Dear all member, I got some problem about slice the solid with surface. I have a solid and I design the surface by loft command and try to slice the solid with that surface. the system said... The Boolean operation on solids failed. Modeling Operation Error: Inconsistent containment of intersection curve. SLICE failed for selected solid. and the other one said .... The Boolean operation on solids failed. Modeling Operation Error: System inconsistency processing edge coincidence. SLICE failed for selected solid. How can I solve this problem?? My surface is extend from the solid edge completely all around 5 mm. I have 4 solid and I can slice it 2 of all. I don't know why. Could any one help me please?? I use cad v 2007. Thank a lot for all suggestion. Regards, Quote Link to comment Share on other sites More sharing options...
nainuad Posted February 20, 2009 Author Share Posted February 20, 2009 I can solved one.. the error said. The Boolean operation on solids failed. Modeling Operation Error: Inconsistent containment of intersection curve. SLICE failed for selected solid. I push the surface down from the solid surface 0.5 mm. and I can slice it completely. Just for all member informations. Quote Link to comment Share on other sites More sharing options...
nainuad Posted February 21, 2009 Author Share Posted February 21, 2009 The Boolean operation on solids failed. Modeling Operation Error: System inconsistency processing edge coincidence. SLICE failed for selected solid. Above error , has anyone know how to fix it? Thank a lot Quote Link to comment Share on other sites More sharing options...
SEANT Posted February 21, 2009 Share Posted February 21, 2009 Can you post a copy of the file with everything removed except for the geometry used for the operation? Quote Link to comment Share on other sites More sharing options...
nainuad Posted February 23, 2009 Author Share Posted February 23, 2009 Can you post a copy of the file with everything removed except for the geometry used for the operation? yes sure but the file that got problem I have solved already. My job still running so I think it will come again. I will post when it get problem a.s.a.p. Thank so much. Quote Link to comment Share on other sites More sharing options...
nainuad Posted February 27, 2009 Author Share Posted February 27, 2009 Can you post a copy of the file with everything removed except for the geometry used for the operation? yes!! it's come again. I have posted the picture for you and all members. I make sure that all the blue surface has cut all completly all solid and extend around 3-5 mm each side. The system said "Modeling Operation Error: System inconsistency processing edge coincidence. SLICE failed for selected solid." I try to change the edge but now it's not work. Can anyone help me? I think CAd is difficult too much for me to design in 3d. Thank you. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 27, 2009 Share Posted February 27, 2009 AutoCAD can only do so much with complex shapes. Maybe it is time to consider another program. 3ds Max? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 27, 2009 Share Posted February 27, 2009 I have posted the picture Post the dwg. Quote Link to comment Share on other sites More sharing options...
nainuad Posted February 28, 2009 Author Share Posted February 28, 2009 AutoCAD can only do so much with complex shapes. Maybe it is time to consider another program. 3ds Max? :D Thanks, I have to learn another program but my job is nearly finish. I had design more than 50% and I found someone and my some friend said I should start with Solid Work. Ok ok next time. Thank you so. Quote Link to comment Share on other sites More sharing options...
nainuad Posted February 28, 2009 Author Share Posted February 28, 2009 Post the dwg. I tried but my file si 650 kb in dwg. How can I post or can I send you by attache an email?? Thank you and sorry for my stupid. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 28, 2009 Share Posted February 28, 2009 You don't need to post the entire drawing, just save out the object shown in your screenshot and post that drawing file. Quote Link to comment Share on other sites More sharing options...
nainuad Posted February 28, 2009 Author Share Posted February 28, 2009 You don't need to post the entire drawing, just save out the object shown in your screenshot and post that drawing file. The picture is above picture that I posted already. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 28, 2009 Share Posted February 28, 2009 The picture is above picture that I posted already. I know that. I'm trying to help you post your drawing file. Save a copy of your drawing. Open the copied drawing file. Delete everything except for the object shown in the screenshot you posted. Purge the drawing. Save the drawing. Post the drawing here in the forum. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 28, 2009 Share Posted February 28, 2009 I tried but my file si 650 kb in dwg. How can I post or can I send you by attache an email?? Thank you and sorry for my stupid. Right click on the filename and select Send to Compressed (zipped) Folder. Attach the resulting *.zip file here. Students can get Inventor Professional for free from http://engineersrule.org Quote Link to comment Share on other sites More sharing options...
nainuad Posted March 2, 2009 Author Share Posted March 2, 2009 I know that. I'm trying to help you post your drawing file. Save a copy of your drawing. Open the copied drawing file. Delete everything except for the object shown in the screenshot you posted. Purge the drawing. Save the drawing. Post the drawing here in the forum. 5555 Thank so much but still 600kb. I had cut any solid that not use to the smallest file but still 280kb. I had zip it and here is for you. The error code is still the same "he Boolean operation on solids failed. Modeling Operation Error: System inconsistency processing edge coincidence. SLICE failed for selected solid." umm... Hey.. Thank you so much for any help. I am appreciated. slice problem2.zip Quote Link to comment Share on other sites More sharing options...
nainuad Posted March 2, 2009 Author Share Posted March 2, 2009 Right click on the filename and select Send to Compressed (zipped) Folder. Attach the resulting *.zip file here. Students can get Inventor Professional for free from http://engineersrule.org Thank you. I done what you said. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 2, 2009 Share Posted March 2, 2009 Thank you. I done what you said. Try the command acisin with these two files. side 1.zip side 2.zip Quote Link to comment Share on other sites More sharing options...
