How can this code be modified to not only match text but also to match the source text's match prop?
Basically I just wanted to have this code by Lee to essentially have the match prop as well. Someone replied to me in the original thread but I can't seem to get it to work.
Lee's code:
(defun c:mt  (/ cEnt mEnt)
 (if (and (setq cEnt (car (nentsel "\nSelect Source Text: ")))
          (member (cdr (assoc 0 (entget cEnt)))
                  '("TEXT" "MTEXT" "ATTRIB")))
     (redraw cEnt 3)
     (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: ")))
                 (member (cdr (assoc 0 (entget mEnt)))
       (entmod (subst (assoc 1 (entget cEnt))
                      (assoc 1 (entget mEnt))
                      (entget mEnt))))
     (redraw cEnt 4))
   (princ "\n<!> Incorrect Selection <!>"))
 (princ))
(defun c:mt2  (/ cEnt mEnt sLst)
     (redraw cEnt 3)
     (if (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "TEXT,MTEXT,INSERT") (-4 . "NOT>"))))
       (mapcar '(lambda (x) (redraw x 2)) (setq sLst (mapcar 'cadr (ssnamex ss)))))
                      (entget mEnt)))))
 (command "_regenall")
 (princ))
(defun c:mt3  (/ cEnt ss)
 (vl-load-com)
     (redraw cEnt 3)
     (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
       (foreach x  (vl-remove-if 'listp
                        (assoc 1 (entget x))
                        (entget x))))))
 (princ))
I tried modifying it (code below) but then despite successfully loading the .lsp via appload and using the correct shortcut name of mt3. It says it is an unknown command.
(defun c:mt3  (/ cEnt ss textColor)
  (vl-load-com)
      (setq textColor (cdr (assoc 62 (entget cEnt)))) ;; get the text color
      (redraw cEnt 3)
                         (subst (cons 62 textColor) (assoc 62 (entget x)) (entget x)))))) ;; update the text color
  (princ)))
This code loads and functions correctly but it still just copies the text and not the text's color as well. Please help.
(defun c:matchTextAndProp (/ cEnt ss textColor)
  (vl-load-com)
      (redraw cEnt 3)
    (princ "\n<!> Incorrect Selection <!>")))
  (princ))
This too won't still work to copy the source's text color :(
  (vl-load-com)
      (redraw cEnt 3)
                         (entmod (subst (cons 62 textColor) (assoc 62 (entget x)) (entget x)))))))
  (princ))
Below is a video of it working with one type of text but not all type of text. Please help.
One of the things with color is if its bylayer then it does not have a color in the entget, no 62, so if its nil then you need to get the Layer color.
Test
(entget (car (entsel "\nPick text ")))
Example
(setq col (vla-get-color (vlax-ename->vla-object e)))
	 (if (= col 256)
	 (setq col (cdr (assoc 62 (tblsearch "LAYER" lay))))
Fixed it. Here is a code:
cc: gileCAD
(defun c:matchTextAndProp (/ cEnt elst text color ss i)
      (setq elst  (entget cEnt)
            text  (assoc 1 elst)
            color (cond ((assoc 62 elst))
                        (T '(62 . 256))
      (redraw cEnt 3)
          (setq elst (entget (ssname ss (setq i (1- i)))))
          (entmod
            (subst text
               (assoc 1 elst)
               (if (assoc 62 elst)
                 (entmod (subst color (assoc 62 elst) elst))
                 (append elst (list color))
